Boolean problem in V3
All  1-5  6-7
6928.6 In reply to 6928.1
Another thing you can do to analyze boolean problems is to select the objects and run Construct > Curve > Isect on them which generates curves at the intersections between objects.
If you then go around and take a bit of a closer look at those curves, if you see any type of irregular boundaries like gaps or pieces sticking out past one another, those are going to be problem areas where there was not a clean intersection.
Like for example in your case here there are some intersection areas like this:
6928.7
Thanks guys, looks like I have to clean up my modeling.
>>Currently there isn't any way to turn on that kind of additional wire display in MoI but I do want to add it in as a type of analysis tool in the future at some point.
That would be a big help for analyzing problem areas I think. But I'll try the Isect Curves to check for intersections if I run into boolean problems again, thanks for that.
-Ronald
Show messages: All  1-5  6-7
