V4 Wish List
 1-9  …  230-249  250-269  270-289  290-309  310-329  …  570-574
6925.270 In reply to 6925.269
Hi 3DFanatic,
> is it possible to add in a scaling option that can be set to reduce the amount of scale
> from farther away in version 4, like a taper effect?
I do want to add in a "Cage edit" type deformation command which could be used for tapering. Right now I'm not sure when it will happen though - hopefully in v4.
> Or possibly being able to control the extrude by also adding an option to extrude less when farther
> away from the point of extrusion if selected.
There is a tapered extrusion option in the current version already, you activate it by pushing this button in the Extrude command:
> Another 1 it would be very cool once setting up a lined section if you could possibly hit a
> button that says all corner section turn into a 90 degree rounded instead of hard edge.
You can use the Construct > Fillet command to do that- if you have a polyline like this:
Select it and run the Construct > Fillet command. Points will be displayed on the corner and the prompt will read "Select corners or push done to do all". If you only want to round off some corners, select those and right click. If you want to do all corners just right click.
Then set a radius and smooth arc pieces will be put into those corner areas:
If those don't do what you were asking about then yes please post an example.
6925.271
Thanks for all that great information this will help me progress thanks. Also thanks for the consideration on the scaling
6925.272
For V4 what about the inclusion of a Mirror Plane which doesnt actually create mirror parts just mirror visual for a live modelling aid when happy with model create an actual mirror - I know history sort of does this but gets broken when you start moving things around.
Another one for the list!
Alex.
6925.273 In reply to 6925.271
One thing i noticed using straight lines to cut an object that has depth it will cut without issue. Basically all sides stay intact but once you fillet the point section then when cutting the edges then the edge is gone maybe to complicated to hold the edge any thought thanks
6925.274 In reply to 6925.273
Hi 3DFanatic,
> any thought thanks
Can you please post the 3DM model file with the object in it that you're having this problem with? It's hard to figure out what might be going on by just a text description like that, I'd need to be able to take a look at your object.
6925.275 In reply to 6925.274
Good evening Michael,
I tried to emulate the same issue but all the test I did created the same open edge. Maybe you can give me some recommendations on how to reduce this issue from happing. I know to close the edge on the hard edge is very simple what becomes more complicated is the curved sections. I kept the lines and main objects that I swept before doing the second action which is what is causing the removal of the edge.
I was able to keep the edge when I extruded the line shape and then Boolean it. However once that is done the edge does not like to be fillet again causes all kind of artifacting.
Again always thanks for your assistance you make this program what it is, thanks
EDITED: 27 Aug 2017 by 3DFANATIC
6925.276 In reply to 6925.275
Hi 3Dfanatic,
What is the second action that you're referring to here, is it using Trim ? If so then when you're cutting a solid it is easier to use boolean difference instead of Trim. Trim operates only on surfaces, while the booleans work on solid volumes and are able to make a solid result automatically joining in the pieces of the extruded cutting curve. You can get the same result with Trim but it's more work because you'd need to extrude the curve into a surface and then trim that surface and join the results together. Booleans basically do all that work for you.
So for your case here with your solid you made from your sweep, select the solid and run Construct > Boolean > Difference, and then select your curve as the cutting object:
That will divide it into 2 solid pieces:
Delete the pieces you don't want and you'll be left with a full solid and won't have to worry about closing up holes as you would if you work only at the surface level with Trim:
One thing to note is that although it works ok for your case here, it's generally not good to have your cutting curve overlap right over top of other areas of the model like in this region here:
That can tend to complicate booleans because it's going to extrude out a cutting surface from that curve and the extrusion is going to be skimming right along the same surface area of your main shape and it's more difficult to get a clean intersection curve from stuff like that. In order to do booleans, a well formed closed intersection loop of curves have to be generated to divide the object up into different clean pieces. If the intersection curves are complex and criss-cross over each other that might not happen.
So instead if possible it's better to have a cutting curve like this where it shoots out a ways instead of having spots that hug right along the same shape:
Then for filleting, the problem there is your shape is very thin and so there isn't much room to fit fillets in, about the maximum size that will fit is around 0.01 units, if you try to use a radius much larger than that it would cause the fillets to collide into each other and cause the type of artifacting that you're describing.
So use a fillet radius of 0.01 or smaller for your particular case here, here's an example of what it looks like with 0.01 :
Hope that helps!
6925.277 In reply to 6925.276
Thanks Michael!
That info helped, after all that do you have plans to give more control on skinnier objects so the fillet can be reduced past the .01 setting? Thanks for all your support
6925.278 In reply to 6925.277
Hi 3DFanatic, you're welcome!
You can do that currently, for your particular case here 0.01 is about the maximum size that will fit, but you can go smaller than that if you want. For example here it is with 0.001 units:
With skinny objects if you get weird results try using smaller and smaller values, don't stop at say 0.1 units, keep going smaller and smaller to get a good idea of what's going to be possible to actually fit there.
With your shape here, a fillet of radius 0.05 takes up this much room just for one side:
It can be a good idea for objects with very small sized features like this to be modeled at a larger scale, like say build this object at 10 times larger than what you've got right now so that you're not working with too tiny values.
6925.279 In reply to 6925.278
Thank you great advice i will increase the whole thing
6925.280
Not sure if this has been mentioned already but here are two suggestions:
Extend surfaces X amount (like in Catia)
Remove chamfer/fillet by selecting and adjacent surface automatically extend (like in Powershape)
Sebastian
6925.281
Hello,
Extrapolation of curves and surfaces would be a great addition to MoI. Scale that model up x10 and you can fillet the edges at .15 to get a complete round on the edges.
Hi Michael.
Have a nice day.
What do you say ? We can except a "hot" October :) ?
V4 is coming ?
Bye!
6925.283 In reply to 6925.282
Hi Michael ...
Yes, I am on pins and needles. You have said 'soon' awhile ago. I'm confused about the definition of that word, :-).
cheers,
eric
6925.284 In reply to 6925.282
Hi Marco & eric - it's getting awfully close! I've got a good path forward for the viewport display, I've been able to modify the rendering library so it matches up with what I need to do and I've got curves and surfaces drawing on screen now.
The main areas left are shaders, background images and text labels, hit testing, and more exploration of a fast path for high memory video cards. I've been thinking that I might release an early version before all that stuff is completely done.
Here's what it looks like at the moment (model by PaQ):
6925.285 In reply to 6925.284
Ok Michael!
We're on the right track!
It seems to be a good starting point.
If you create some shader to apply to the base rendering it could become interesting.
I mean, ambient occlusion and some shader with environement illumination/reflection.
I stay tuned.
Thanks.
6925.286 In reply to 6925.285
Hi Marco, well the first priority is for shaders that make curve and surface drawing look the same as V3.
For ambient occlusion that's something that I'd like to look at later on, but probably initially in a simple "offline" renderer. That's not something I'm targeting for the first V4 beta release though.
6925.287 In reply to 6925.286
OK. No Problem.
For me the most important things of the new display engines should be these :
1) Improved antialiasing (both for curve/edges and surfaces)
2) No "display glitches"
3) Speed. Moi must take advantage of the modern GPU, if it is installed on the machine where Moi is executed.
I hope these things will be done within the V4 beta period.
Have a nice day.
6925.288 In reply to 6925.284
Hi Michael
Thanks for the response. I can hardly wait to start using the beta 4.
cheers,
eric
6925.289 In reply to 6925.287
Hi Marco, for #1 curve antialiasing in MoI is pretty much already as good as it's possible to do so I don't really expect to be able to improve that in particular. Do you have an example where it isn't working well?
For #2 I'm afraid that display glitches in the viewport display are difficult to avoid without taking a hit in speed at the same time. I do have some ideas on possibly improving that particular type of artifact but it remains to be seen how much of a speed hit will be involved.
For #3, that is something that I do intend to focus on, however your other requests would generally come at the expense of speed so you're kind of asking for mutually opposing things on your list here... ;)
Show messages:  1-9  …  210-229  230-249  250-269  270-289  290-309  310-329  330-349  …  570-574
