V4 Wish List
 1-4  …  105-124  125-144  145-164  165-184  185-204  …  565-574
6925.145
Things I would love:
- better scene management (instances, nested groups)
- line types and weights for curves, that can be maintained during the export in .AI and .DXF formats.
- annotations (dimensions and editable text tool)
- option to clip the view of the current CPlane (clipping plane)
These are the most useful to me.
M.
6925.146
...Not sure how plausible...
a macro recorder with JavaScript output would be great for those of us who are not so sophisticated with coding.
Well, this is a "Wish" List...
-- MindSet
6925.147
That's the way (I think) how should works fillet and chamfer
Size: 721.1 KB, Downloaded: 69 times, Dimensions: 489x330px
Seems my gif file from free DesignSpark Mechanical! :)
6925.149 In reply to 6925.147
I believe BOTH ways (to a point and fusions constant, are valuable.
6925.150 In reply to 6925.148
ehmm
yes :)
6925.151
for me that a wish for V4 would be a Linux version - as I still haven't managed to get MoI usable through WINE. I can get it to run easily but there's a visual glitch that makes it non workable (it's like display is one frame behind actual state - for example when I make a selection the "marquee" stays on screen until I move the cursor. What's worse this affects highlighting the selection - tough to explain , if anyones interested I can work out a video). Tried on 3 different systems, with different configuration - happens every time.
And damn, I would really love to have a NURBS modeler on Linux - apart from mid lvl video editing , CAD is something where choices on Linux suck badly. At the very least dcc apps are covered thx to Modo / Maya / Houdini (... and Blender).
6925.152
Michael I was wondering if you have any plans of incorporating real time filetting in V4 ( a la Spaceclaim, DesignSpark).
To me it is MOI's main weakness/time sink right now.
6925.153 In reply to 6925.152
Hi niko, I've had some thoughts that I'd like to look into that. So we'll see - no firm plans yet though. It depends on getting filleting handled by a different geometry library and how reliable the library is.
6925.154 In reply to 6925.153
I don't know if anyone already posted, but I suppose that numeric coordinates editor is a must also.
6925.155 In reply to 6925.154
Hi glmr, I would definitely not take away numeric input for the fillet radius value, the part that would be modified would be setting it using the mouse.
6925.156 In reply to 6925.155
I mean objects and gropus position/orientation. X,Y,Z with a possibility to move them via coordinates system.
6925.157 In reply to 6925.156
Hi glmr, you can already use the Transform > Move command currently to move a point on an object to a specific X,Y,Z coordinate already.
I guess you're asking though about objects having a sort of "local axis" point that you could set. That tends to be something that's used by animation systems though and not so much with CAD programs like MoI.
EDIT: Well except for instancing, that should have that type of thing.
6925.158 In reply to 6925.157
How can I move a point to a specific XYZ?? I'm trying but see usual dialogue - boundary box, distance from edge etc. so, I can set XYZ in window, but I need to change evrything in this way. so it is not possible to change one axis only
6925.159 In reply to 6925.158
Hi glmr,
You just type in the X,Y,Z value when it's asking you for the target point. You'll see your keystrokes go to the XYZ coordinate input in the bottom toolbar:
6925.160 In reply to 6925.159
it would be netter ho have such option as in Rhino - just choose an object and edit each parameter without re-type al of them
6925.161 In reply to 6925.160
Hi glmr, I don't remember Rhino having any feature like that, it must be relatively new. Can you describe it a bit more?
6925.162 In reply to 6925.161
Hi Michael.
I think glmr is referring to BoxEdit command of Rhino V5.
Look at this video : http://take.ms/ddgch
See you.
6925.163 In reply to 6925.162
Hi Marco, you can do the sizing part of Rhino's BoxEdit command in MoI by clicking on the size line in the properties panel, it will show an "Edit size" menu like this:
@glmr - if you can describe in more detail what you need for positioning, it's pretty likely I could make a plug-in for you to do it.
6925.164 In reply to 6925.163
Hi Michael.
@Michael "Hi Marco, you can do the sizing part of Rhino's BoxEdit command in MoI by clicking on the size line in the properties panel, it will show an "Edit size" menu like this:"
I already knew that editing feature of Moi but thanks anyway for the reminder.
I told you about Rhino's BoxEdit command only because it has some additional features that Moi's Edit Size doesn't have.
But IMHO are negligible things.
See you.
Show messages:  1-4  …  85-104  105-124  125-144  145-164  165-184  185-204  205-224  …  565-574
