Hi Arian, I do want to look into 64-bit support for MoI in the future. There will be a lot of work involved so I'm not entirely sure when it will happen though. Definitely not for the next v3 release which will probably be out next week though. I hope to do some investigation during the v4 time frame.
In the meantime, if your models are approaching around the 3.6GB ram consumption level you will probably need to break them apart into multiple separate files rather than just one single giant one in order to avoid MoI running out of 32-bit address space.
Also it can help a lot if you adjust some display settings to make a rougher display mesh. By default MoI makes a pretty dense display mesh which makes the shaded display look nice on screen but tends to consume quite a bit of memory if you've got a highly detailed model. To use a looser display mesh density, go to Options > View > Meshing parameters and change "Mesh angle" to a rougher angle like 25 or 30 degrees and uncheck "Add detail to inflection".
Changing those settings will result in a somewhat rougher and more jaggedy looking shaded display but can also substantially cut down on the amount of memory being used.
But you still don't want to push MoI to operate very close to the approx 3.6 GB memory limit it has because if it runs out of memory it can lead to unstable behavior. If you're near to that size you will need to separate your project into different pieces to avoid problems.
