Archimedean Spirals script, Chinese YinYang
All  1-6  7-9
6906.7 In reply to 6906.6
Hi Brian!
>>Somehow, the latest ArchimedeanSpirals script is getting away with theta=0.
add line:
if (theta===0) { theta=0.0000001 }
>>The onmousemove slider generates the flashing curves, I would guess from repetitive calculations.
Check the new code (attached)
Use diff tool, or any online tool like http://www.quickdiff.com/
P.S. Thank you for a moi.ui.fireUIEvent command :) I didn't know about it :)
EDITED: 7 Mar 2022 by SMIRNOV
6906.8 In reply to 6906.7
Hi Max
Michael provided the code/information on moi.ui.fireUIEvent and onmousemove, for the Clothoid2ptSliders script.
I will try to use your improvements for the Clothoid sliders.
Thank you for the diff tool information.
Checking out your code shows 3 improvement areas.
1. Corrected divide by zero potential error.
2. Greatly reduced slider flickering.
3. Clicking on one of the 4 spiral families switches the spiral to that type.
I am posting a zip of your two files to post #1, replacing the older script.
I need to improve my haphazard version control.
Also, Thank you for your impressive improvements. I had no idea how to do them.
EDITED: 13 Sep 2014 by BEMFARMER
6906.9 In reply to 6906.8
I successfully modified the Clothoid2pt script with the low flicker sliders.
I'll wait a day or two to check it out. It is too late right now.
Also added (for example)
 <td onclick='end_slider.value=180; moi.ui.fireUIEvent("end_slider");'>End Angle:</td>
to reset the endpoint slider to its midpoint value.
This reset to midpoint value should work on the Spirals, FxGraph3D, and would even work for Blend (?), but I'll leave the latter two alone.
EDITED: 14 Sep 2014 by BEMFARMER
Show messages: All  1-6  7-9
