Archimedean Spirals script, Chinese YinYang
All  1-3  4-9
6906.4 In reply to 6906.3
The family of Archimedean Spirals has the polar equation r = a * Theta(power(b)).
The script avoids using b=1/n, to avoid division by 0 if n=0.
b = the tightness of the Whorls.
For Archimedes' spiral, b = 1. Its inversion is the hyperbolic spiral, b=-1.
For Fermat's spiral, b = 1/2. Its inversion is the lituus, b=-1/2.
Other values of b yield different curves.
The minimum tightness is set to -1.0, because lower values hung up Moi. If b < -1, b = -1
The maximum tightness is set to +3.0.
Fermat's spiral is also known as the parabolic spiral.
The hyperbolic spiral is also known as the reciprocal spiral.
If b = 0, whorls of "circle(s)" forms. (On top of itself)
The "circle" is not quite as perfect as a Moi Nurbs circle.
6906.5 In reply to 6906.4
>>The following does not work for negative b:
>>ArchimedeanSpiral:
>>_FxGraph3D a*pow(v,(1/b))*cos(v)/PI;c*pow(v,(1/b))*sin(v)/PI;0;0;1;0;6.283185307179586;0;50;6;1;6;U
Hi Brian
it works, but your settings is not correct.
For example, v=0, b=-2
pow(v,(1/b))*sin(v) = pow(0,-0.5)*sin(0) = infinity * sin(0) = infinity * 0 = indeterminate => math error
to avoid this use minV=0.0001
_FxGraph3D a*pow(v,(1/b))*cos(v)/PI;c*pow(v,(1/b))*sin(v)/PI;0;0;1;0.0001;6.283185307179586;0;100;6;-2;6;U
P.S. Thank you for your scripts! This one is great (as always)
EDITED: 13 Sep 2014 by SMIRNOV
6906.6 In reply to 6906.5
Thank you Max. I continue to learn a lot from your professional scripts, even though I do not understand all of their details.
Link to negative exponents: (It is basic algebra :-)
http://www.regentsprep.org/Regents/math/algtrig/ATO1/posnegzles.htm
A couple of questions for Max and Michael:
Somehow, the latest ArchimedeanSpirals script is getting away with theta=0.
So maybe Moi is compensating??
I tried an alert message to see the result of pow, but that prevented the script from working.
The onmousemove slider generates the flashing curves, I would guess from repetitive calculations.
Maybe with some sort of onmousemove (stopped moving), the values could be purged?
6906.7 In reply to 6906.6
Hi Brian!
add line:
if (theta===0) { theta=0.0000001 }
Check the new code (attached)
Use diff tool, or any online tool like http://www.quickdiff.com/
P.S. Thank you for a moi.ui.fireUIEvent command :) I didn't know about it :)
EDITED: 7 Mar 2022 by SMIRNOV
6906.8 In reply to 6906.7
Hi Max
Michael provided the code/information on moi.ui.fireUIEvent and onmousemove, for the Clothoid2ptSliders script.
I will try to use your improvements for the Clothoid sliders.
Thank you for the diff tool information.
Checking out your code shows 3 improvement areas.
1. Corrected divide by zero potential error.
2. Greatly reduced slider flickering.
3. Clicking on one of the 4 spiral families switches the spiral to that type.
I am posting a zip of your two files to post #1, replacing the older script.
I need to improve my haphazard version control.
Also, Thank you for your impressive improvements. I had no idea how to do them.
EDITED: 13 Sep 2014 by BEMFARMER
6906.9 In reply to 6906.8
I successfully modified the Clothoid2pt script with the low flicker sliders.
I'll wait a day or two to check it out. It is too late right now.
Also added (for example)
 <td onclick='end_slider.value=180; moi.ui.fireUIEvent("end_slider");'>End Angle:</td>
to reset the endpoint slider to its midpoint value.
This reset to midpoint value should work on the Spirals, FxGraph3D, and would even work for Blend (?), but I'll leave the latter two alone.
EDITED: 14 Sep 2014 by BEMFARMER
Show messages: All  1-3  4-9
