FLOW - Complite guide.
All  1-5  6-8
6896.6
Thanks Andrei
Thats brilliant , I had a play with flowing text and the history enabled is useful to adjust where it ends up and the angle it flows to.
Michael is there any chance of adding History to arraycurve ? as I flow gemstone objects or setting beads along a curve all the time then have to delete them and adjust it and redo until I get them in the right positions.
No problem if it is too difficult. Or can I turn history update on before running arraycurve
or will this be too taxing on the computer system to keep track of.
cheers
shayne
6896.7 In reply to 6896.6
Hi shayne,
Currently it's disabled because the way the history mechanism works it added quite a lot to the file size when the history information was included in the array commands.
In the future I would like to make it possible for them to work, but probably an instancing mechanism would be the main way to do it, we'll see.
6896.8 In reply to 6896.1
Another great tutorial, Andrei, thank you! I've learned a lot from your tutorials.
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
Show messages: All  1-5  6-8
