Sharp points delete, script request.
All  1-12  13-18
6890.13 In reply to 6890.2
>> currently there is no script interface set up to allow scripts to access the individual edit points of a curve
Hi Michael!
Could you implement this interface in the future versions of MoI?
It will be very powerfull tool for scripting.
Something like this:
curve.getControlPointCount()
curve.getControlPoint(index)
curve.setControlPoint(index, newcoords)
and for surfaces:
surface.getUControlPointCount()
surface.getVControlPointCount()
surface.getControlPoint(U_index, V_index)
surface.setControlPoint(U_index, V_index, newcoords)
6890.14 In reply to 6890.13
Hi Max, yes I do want to add something like that in the future. If you can bring it up again during the v4 development cycle that would be a good time for me to dig into it.
EDITED: 2 Sep 2014 by PILOU
6890.16 In reply to 6890.15
Hi Pilou, for the case you show there, just draw in a new 3 point curve using Draw curve > Freeform > Control points, you'll then have the new segment in the shape you want.
Or another possibility is to use Edit > Separate and then Edit > Join and only join the ending 2 segments together and then run DelCorners on that...
6890.17 In reply to 6890.16
Yes :)
It was just for know! :)
First method is more suitable and easy!
Mine is draw a new "no corner point" near the old corner then kill the corner point and move the new on the old! :)
French version :) http://moiscript.weebly.com/delcorners.html
English one
Show messages: All  1-12  13-18
