A small continuity problem there
All  1-2  3-5
6888.3
Hello Samuel,
It looks like you have a very slight issue at your corners, they are G1 but not G2. The region where the sides meet the top are G2 but not G3. It would be very hard to tell there is something a bit off there without the zebra pattern and analysis. Hope the data helps.
6888.4
Thanks! I fixed the naked edge problem
For the continuity I think it will be ok now because I only do fixed camera position renders where you don't really see the backside anyway
Hope that MoI will get matballs support one day so we can have something like zebra :)
Kuto.ch / freelance graphic designer and 3D generalist
6888.5
Hello,
A G2 blend between surface edge 12 and 14 seems to work well and the resulting surface edge 13 looks a bit cleaner.
Show messages: All  1-2  3-5
