very close
 1-9  10-29  30-49  50-67
6875.10 In reply to 6875.9
Michael has already announced that we are within the grace period for purchasing the current product (V.2) and getting a free upgrade to V.3 when it is released.
I was in the same boat, waiting to purchase because I didn't want to hit up accounting for an upgrade right after purchasing the program.
Come on in, the water's FINE!
EDITED: 9 Sep 2014 by MARKG
6875.11
Cool Michael
Is the final going to include history for the flow command?
6875.12 In reply to 6875.11
<< Is the final going to include history for the flow command?
Even not it's so easy to copy paste the modifyed file inside the folder commands! ;)
6875.13 In reply to 6875.9
Hi Michael (Findus) - yes like Mark writes above if you order v2 now you'll get a free upgrade to v3 when it is released.
6875.14 In reply to 6875.11
Hi niko,
History already works with the flow command, just enable history updates on the deformed object.
To enable it you can select the output of the flow command and run Edit > History > "Enable update".
It's also possible to set up a shortcut key that enables history updates on whatever objects were created by the last run command, maybe that will be useful for you. To do that set up the following on a shortcut key:
script: /* Enable history updates on objects created by the last run command */ var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.updateWithHistory = true; }
If you want history to be enabled by default on Flow so you don't need to do any other steps to turn it on, that's also possible currently as well by modifying the flow command script. Overwrite the existing command script with the flow.js file attached to this message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6896.1
This will be all the same for the final version.
6875.15
that sounds great, I will go and get it today.
Thanks!
Findus/Michael
6875.16 In reply to 6875.1
I've got the final v3 version built and it's ready to go, there are just various other things to finish up like making an official announcement, updating web pages, etc... Maybe I'll set up the order pages first so people can order it early while I'm still working on the various announcement stuff.
6875.17 In reply to 6875.16
I am ready to order. The weekend will be good to get set up.
Brian
6875.18 In reply to 6875.16
Oh! Getting all excited now :)
Martin Spencer-Ford
6875.19
The suspens is killing me!
Already have two new projects to test this V3 :)
Kuto.ch / freelance graphic designer and 3D generalist
6875.20 In reply to 6875.17
6875.21 In reply to 6875.20
Ready
6875.22 In reply to 6875.21
Ok, this will be an early "soft" release here - the official release with proper announcements and whatnot will happen probably next week but if you want to order v3 now here you go:
Upgrade version ($100) :
https://moi3d.bluesnap.com/jsp/buynow.jsp?contractId=3245446
Full version ($295) :
https://moi3d.bluesnap.com/jsp/buynow.jsp?contractId=3245444
If you have purchased any previous version (including just v1 or an edu version) you can order the upgrade version instead of the full version. This will be the version for most people here on the forum. Only order the full version if you have never purchased any previous version.
If you've ordered MoI v2 fairly recently like within the last 4 months or so, then hold off because there will be a free upgrade for people who ordered v2 recently.
When you place an order you'll receive a license key and download link for the v3 full version through e-mail. The main changes since the last v3 beta are documentation updates but there are a few minor bug fixes too and of course the biggest difference is the full version does not have any expiration! :)
Please let me know if you run into any problems!
Feels great having V3 being active, it's been a long time coming! :) :)
6875.23 In reply to 6875.22
And by the way Brian has placed the first order for MoI v3, thank you very much Brian!
6875.24 In reply to 6875.23
Brian....... The guy's like a machine!!!!
Congratulations Michael.... What a product....:)
6875.25
Sweet! Gonna buy this first thing when I get home! Congratulations, Michael for all the hard work!
6875.26
Congratulations on the new release. I purchased my update and installed it without issue. Thanks for all your hard work on a great program!
_________________________
Don Cheke
Visit: Textual Creations
6875.27
Michael, thank you very much!
Just upgraded to v3. Everything works great :)
6875.28
Instant buy of course, thanks a lot for the little gem !
Thanks very much everyone! :)
Show messages:  1-9  10-29  30-49  50-67
