Put Back Command
All  1-4  5-7
6872.5 In reply to 6872.4
Hi Samuel,
> Also what I usually do in my workflow when Isolate is not enough is that I pick the move tool and
> move the part by a fixed value like 100 units in 1 axis
> Just pick the move tool then type 100 and done, then you can work on it and after that you just
> move it back by the exact same value :)
You can also do this by object dragging without needing to trigger the move tool.
Type your distance value in before you do the drag, it will then use that as a distance constraint during the drag operation.
If you do this a lot you can also use this script on a shortcut key to trigger a fixed distance constraint with one keystroke:
script: /* Set distance constraint of 100 */ var pp = moi.ui.getActivePointPicker(); if ( !pp ) pp = moi.ui.createPointPicker(); pp.setDistanceConstraint( 100.0 );
The shortcut key for that can be triggered either before or during the drag.
6872.6 In reply to 6872.5
This is great learning, thanks!
6872.7 In reply to 6872.3
Wow, the Ctrl + click on the Hide button is a very useful tip, thanks once again Michael!
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
Show messages: All  1-4  5-7
