Flow question
All  1-5  6-17
6871.6 In reply to 6871.5
Fully understood, thanks again. I've done a test, and indeed a lofted surface works as expected, so that's the method I will use from now on to create Flow target surfaces.
Have a nice weekend,
Metin
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6871.7 In reply to 6871.6
another big advantage with loft-command or sweep (with deformed rails and profile),
you can deform uv and get different results by flow-command,
without "base object" modification.
example for loft
before you finish loft-command with "done", move seam-dots direction.
or bevore loft, add more profile.
with sweep, similar, but direct with profile curves.
-EDDI
6871.8 In reply to 6871.7
Thanks a lot Eddi, much appreciated. This gives me a new insight in the way MoI works.
6871.9 In reply to 6871.8
and here is last one example with sweep "area deform",
on picture
Blue lines > Rails
Yellow highlightet > Profiles
-EDDI
6871.10 In reply to 6871.9
Very interesting, thanks for the explanation! I didn't realize yet that you can influence surface topology and its Flow result by a Sweep profiles layout.
6871.11 In reply to 6871.9
eddi, thank you very intresting observation!
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
6871.12 In reply to 6871.11
1
6871.13 In reply to 6871.12
Hi Andrei,
i do not speak English, only German and Czech, a proper brake here to post.
so hoping for you and your excellent understanding in 3D,
maybe a new theme for your famous tutorials ???
best regards
-EDDI
6871.14 In reply to 6871.13
Hay eddi, I'm not sure I understand what do you mean :)
6871.15 In reply to 6871.14
Hi Andrei,
i mean, you make very good tutorials,
can you make one for the "flow manipulation" ?
this can help other users with FlowPower!
regards
-EDDI
6871.16 In reply to 6871.15
Hi eddi,
I made it already yesterday but not posted it. This is it:
6871.17 In reply to 6871.16
Great video, Andrei! Vă mulțumim!
Show messages: All  1-5  6-17
