another big advantage with loft-command or sweep (with deformed rails and profile),
you can deform uv and get different results by flow-command,
without "base object" modification.
example for loft
before you finish loft-command with "done", move seam-dots direction.
or bevore loft, add more profile.
with sweep, similar, but direct with profile curves.
-EDDI |
