Need some help with fillet
All  1  2-8
6868.2
Hello,
What distance and shape parameters are you trying to use for each part? I'm sure Michael has an explanation for it, however you can use those fillet parts to make a watertight solid. Make a Copy of your original solid, Hide the one copy of the solid, run the Fillet operation on the copy of the original solid. You should be left with fillet parts. Separate the fillet set and clean it up so it is symmetrical. Now Join the fillet set into a joined surface. Now you can select the inner edges of the fillet set and Join them, these curves will act as your trimming curves for the unfilleted solid. Unhide your original unfilleted solid and Separate it. Use the trimming curves you created to then Trim the surfaces, leaving the inner trimmed surface is removing the outer. Now unhide your fillet joined surface, and Join it to the inner trimmed surfaces. You should be left with a watertight Solid. Hope this helps.
6868.3 In reply to 6868.1
Hi Glenn yes, unfortunately Fillet is a very sensitive operation and there are a lot of things that can go wrong with it.
In your first screenshot for filleting the bottom part, the problem there is that it looks like you're asking it to use a fillet radius that is too large to fit in the available space. If you ask for a fillet radius that causes fillet pieces to run into each other that will cause problems.
In your case here it's this area here that is the limiting factor:
Note what happens when I start with a smaller radius like 0.1 and increase it gradually up to 0.9:
Notice how the space there is shrinking away as the fillet radius increases?
At radius = 0.9 the available space is almost entirely consumed. At radius 1.0 as you show in your screenshot, there isn't enough space for the fillets to fit without colliding into one another and that's when you will get problems.
So for that particular piece you will need to limit your radius to a small enough value that it can fit, like not greater than 0.9 .
You get that sort of strange inversion effect when things run into each other because the ordered sense of directions becomes confused when pieces overlap each other. Hope that helps to explain that particular type of thing.
For the top piece, that's a different problem it looks like there is some bug in trimming the fillets there. When fillet had some problem trimming things, it will still output the fillet surfaces so that you have a chance to still use them to finish it up with a manual trim or boolean operation, like OSTexo mentions above. It looks like it should be possible to salvage the fillet in this way, let me know what particular fillet parameters you want to use there and I'll see about getting the pieces into place to get you a finished result.
6868.4
Hi OSTexo, Hi Michael,
I run into these type of thing a lot when I'm using fillet.
Most times I try until something works or try something else.
I've been doodling for most of the time now.
Trying to learn the features and tools of MOI .
So now that I'm really starting to make actual models I want know if im doing things wrong or how to fix things.
So thanks for the detailed description on how to salvage the fillet OSTexo.
I will give certainly give it a try.
The problem with the bottom part is clear to me Michael.
Thank you to for the detailed explaination.
The problem with the top part is what I encounter the most when using fillet.
But if I understand correctly there nothing I can do different to prevent this from happening?
There is nothing wrong with the way I modeled the solid or something?
If it does happen, the only thing I can do is to try OSTexo's method of trying to salvage the fillet parts?
If it's a bug that can be fixt in the future.
Maybe it's helpful for you, If I send you a file each time I encounter such a problem?
Regards,
Glenn
6868.5 In reply to 6868.4
Hi Glenn,
It doesn't look like you've really done anything wrong there, I would have thought that should work.
But you may be running into some general problems related to constructing objects at a somewhat larger scale, you may be able to get some more reliable results if your objects are something like maybe 10 units across in size rather than hundreds of units across.
I've attached a reconstructed version of your object, which I did by scaling it down 1/10 from your original size, then extracting the edges and building new lofted surfaces between them. This reconstructed version does not seem to have any problems with filleting anymore.
If this is something that you're running into frequently you might try just generally drawing and creating things at a little bit smaller size, something like having things at around maybe 1 to 50 units across.
Also from the structure of the surfaces, it looks like you're building this by arranging several 3D curves into place and then constructing surfaces between them. I wouldn't really call that "wrong", but it may be slightly better to try and use 2D extruded surfaces when possible, so like in this case here starting with a block and then doing booleans with 2D curves to slice off chunks of the block rather than doing it all with surface construction between 3D curves.
It does look like it's a bug. Right now I'm not sure exactly what it's sensitive to, unfortunately it's very difficult and time consuming to do a proper diagnosis. Also it's a particularly easy area to introduce new bugs into when trying to change things to fix a particular case. If you run across cases like this in the future it would be helpful for you to send them to me (please e-mail to moi@moi3d.com), if I get several test cases to work with that does help a lot when I would try to do a fix for it.
6868.6 In reply to 6868.3
Hi Glenn, I also tried reconstructing your object at it's existing size by lofting new surfaces, and this new version also seems to behave ok for filleting (attached).
Maybe what you have been running into is a previous bug in Loft where it would sometimes not generate a tight enough fitting tolerance and not make a quite accurate enough result.
That was a bug that was fixed though in the most current v3 beta, are you running the Jun-27 v3 beta version or are you possibly running an earlier version than that?
If you happen to have the original curves that you used to construct that top piece, could you please send those over and tell me which specific method you used for the construction? That might help me to figure out what was different about your original model you posted versus the one I constructed and attached here...
6868.7 In reply to 6868.6
I will look into the scale thing in the future.
How I constructed the top part:
-I started from rectangle, made a plane and extruded it to a box.
-then I drew my curve in front view , mirrored them, and trimmed it on the surface of the box.
-then I used the extrude tool to push the side pieces away until they disappeared.
( I started out modeling with sketchup, so the new extrude auto Boolean thing kind of makes sense to me = push/pull tool in sketchup )
- next I copied and orated one of my trim curves to line up with my Right view and adjusted it a bit.
- I trimmed this adjusted curve on the solid
- did another push extrude until the part disappeared and had my solid as. It is.
Since had some problems with the fillet tool.
I checked some things out and noticed that the front two curves of my solid was made out of multiple pieces and had to be selected separately ( I think because of pushing the trimmed surface in 2 directions?)
So I joined them, giving me a new curve.
I deleted the front plane, deleted the original (broken) curves and replaced them with the new ones.
At first I did a network on the top front to reconstruct that curved surface, but that didn't help the fillet.
So I went back and did a loft instead.
If I recall correctly, I think I lofted all 3 curved surfaces like that.
At least 2.
I can't send you a file right now,
But I should have a file with the original curves in it, so i can send it to you tomorrow when I'm back at my office.
6868.8
Hello Glenn,
It just so happens that you're able to get those last two bottom fillets to be a value of 1 and have it end up a nice watertight solid. The key is to extend the bottommost box along the long axis so you can Fillet the lines you indicated with a value of 1. Then just create the bottom box again and select a Fillet operation of 1 on the lines you indicated. Remove the internally created faces and Join the two surfaces together into a Solid. Those fillets along the top edge between the two major parts of your model will probably require a bit more thinking to blend in nicely.
Show messages: All  1  2-8
