MoI wishlist
 1  2-21  22-41  42-61  …  82-98
6864.2 In reply to 6864.1
Hi Metin, that's a great list. I'd definitely like to get some of those implemented for v4, but some of them are very time consuming areas of work though.
Re: 08: Option to scale a selection without deformation. In other words: moving objects closer to each other or away from each other to or from a center point, without scaling the objects.
For this try the ExplodeMove command:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2781.3
http://moi3d.com/2.0/docs/moi_command_reference10.htm#explodemove
6864.3 In reply to 6864.2
Many thanks! Looking forward to see one or more of my suggestions in a future MoI version.
ExplodeMove does exactly what I was looking for, thanks! I had read about it before, but thought it would also separate surfaces in selected solids, but now I know it only does that when a single solid is ExplodeMoved.
Have a nice Sunday,
Metin
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6864.4
Hi again,
I've changed number 8 to the following wish:
History enabled (by default) for arrays, so you can change the base object and see the change propagated to the copies in realtime.
Metin
6864.5
To be honest the priority I'd want to see are object instances. One cannot afford to change 100 identical objects manually if one changes.
Max.
6864.6 In reply to 6864.5
Thanks Max, I second that, and will adjust the array history wish accordingly.
EDITED: 17 Aug 2014 by SEVENSHEAVEN
6864.7
Added:
11: An object name list dialog addition to the Import function, to import only selected named objects / object sets from an other MoI scene, in stead of importing everything. Every named object / set in the list could be checked by default, with Select All, Select None and Select Invert options included.
6864.8
Let's say that for example I have a lamp with 15 identical screws in it.
I modeled everything, but I realize the 15 screws look bad, so I want to edit them. I want to edit just one of them, and the rest will update accordingly.
The lack of this feature got me frustrated many times, and (being honest) I thought about switching to another software, but I love it too much, so I always made the effort.
So I can already see that, see that new list in the browser named "components".
Best wishes :)
Max.
6864.9
Hi, some good ideas in that list. Here's a couple I would like to see at some point:
A method for arranging objects into groups as shown below
A way of assigning a pre-existing name to a newly created object...
:-) Mark
6864.10
I would like to see a more powerful fillets package.
Also a way to better organize the Objects list.
6864.11 In reply to 6864.9
Hi Mark,
There are a couple of plug-ins that can help with this currently -
AssignName - set the name of an object from a list of existing named objects:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.4
AssignPresetName - set the name of an object from a fixed preset list of names in a text file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.8
6864.12
Changed my top-priority wishlist entries to:
• A view-based move, rotate and scale tool, for quick view-based manipulations in the perspective view. I really miss this.
• A local coordinate system, remembering the orientation, scale and direction of each object, with a matching move/scale/rotate gadget around it when objects / elements are selected.
Maybe it's already possible. In that case I'd love to know how. Right now my workaround is to set the CPlane to a new object orientation every time, and switch to a front/side/top view to get the rotate/scale gadget around my selection. But that's too elaborate.
EDITED: 19 Aug 2014 by SEVENSHEAVEN
6864.13
FISRT! Polygonal like modeling (Like T-Spline)!
SECOND! Instances!
My Portfolio: www.samardac.com
A lot of my Tutorials!
6864.14
Thanks Andrei,
I've read about Rhino's T-Splines. Would be great indeed. The perfect cross-over between poly and NURBS modeling.
6864.15 In reply to 6864.12
Hi Metin,
Check out here for a script that will set the cplane to the 3D view direction, that might help to ease this process somewhat:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2599.4
6864.16 In reply to 6864.15
Hey, that's great, thanks for the pointer, Michael!
Just added this to the list (no high priority for me, but very welcome nonetheless):
• A smooth / relax function for a selection of curve / surface points, with an adjustable strength / number of iterations.
6864.17
Added (medium priority to me):
• Viewport navigation enhancements:
— Resizable viewports in the quad view, so you can make one or two views larger without having to switch to a full-screen view.
— Ability to switch to a left / back / bottom view in the quad view, in stead of having to go full-screen for that.
— A camera / viewport roll control (e.g. middle or right pen/mouse button together with Alt, Ctrl or Shift).
EDITED: 20 Aug 2014 by SEVENSHEAVEN
6864.18 In reply to 6864.17
Hi Metin,
See here for how to set up a shortcut key to do this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6680.2
Set up the following script on a shortcut key and it will allow you to do that - when you trigger it, it will reverse the view that the mouse is over:
script: /* Reverse view under mouse */ moi.ui.mainWindow.viewpanel.reverseView( moi.ui.getActiveViewport().name );
6864.19 In reply to 6864.18
Muchas gracias, señor Michael! This is very useful.
6864.20
I wanted to stop throwing my two cents, but here I go again.
While MoI is an excellent tool for modeling (best I ever used so far), at the moment it lacks some very important features that are mandatory to start competing with other software on the market.
For most of us, modeling is fun, but it's pointless if we cannot easily produce the technical documentation needed. And you know that, you cannot deny that you HAVE to switch to another software for that. For example I had to import into Rhino for making simple sections, which is absurd.
Modeling and drafting:
- Dimensions and simple constraints (ref. http://solvespace.com/index.pl).
- Simple drafting tools such as line types and thickness as properties of a style, text, hatches.
- Dynamic boolean difference,
- cutting planes for making the production of technical drawings faster and in a non-destructive way. They help a lot during the thinking process, too.
Project management:
- Instances.
- Nested groups.
- Please an optimization in the object stack when in isolation mode. In complex scenes, drawing starts to become sluggish.
So that's really all.
Thank you for your time.
Max.
6864.21 In reply to 6864.20
Max ...
Yes ... those are the ones I wish for, too.
I wince a little every time I have leave MoI to finish my working drawings.
cheers,
eric
Show messages:  1  2-21  22-41  42-61  62-81  82-98
