Isocurves on several faces.
All  1-3  4-5
6862.4 In reply to 6862.1
Here's a kind of simple example, see the attached 3DM file. Generate an isocurve along the plane like this:
If you now generate an isocurve on the sphere at that same ending location, you'll get a result like this:
The plane isocurve follows the UV structure of the plane, the sphere isocurve follows the UV structure of the sphere, each of those surfaces has a fairly different control point grid structure to it, and so their isocurves do not follow a total straight path when done segment-by-segment like that.
If you want something that follows a straight cut path across surfaces, that's going to be a planar intersection curve which is a different type of generation process than an isocurve. You can get a planar intersection result by projecting a line onto the object though.
6862.5 In reply to 6862.4
Yes I know about project, but sometimems it produces a lot of points.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Show messages: All  1-3  4-5
