Isocurves on several faces.
All  1-2  3-5
6862.3 In reply to 6862.1
Hi Andrei,
> Hallo Michael, is it possible to make isocurves to work on
> several faces simultaneously and follow one cuvrve?
It's difficult because there is no guarantee on any arbitrary joined set of surfaces that isocurves from each adjacent surface will make a closed loop like that. The U/V directions of each surface at joined edges are not necessarily aligned to one another.
What you show there looks like a planar section cut which you can do currently by drawing a line and using Construct > Curve > Project. Select the line, run Construct > Curve > Project, and then select your solid as the target object and you should get a result like that.
6862.4 In reply to 6862.1
Here's a kind of simple example, see the attached 3DM file. Generate an isocurve along the plane like this:
If you now generate an isocurve on the sphere at that same ending location, you'll get a result like this:
The plane isocurve follows the UV structure of the plane, the sphere isocurve follows the UV structure of the sphere, each of those surfaces has a fairly different control point grid structure to it, and so their isocurves do not follow a total straight path when done segment-by-segment like that.
If you want something that follows a straight cut path across surfaces, that's going to be a planar intersection curve which is a different type of generation process than an isocurve. You can get a planar intersection result by projecting a line onto the object though.
6862.5 In reply to 6862.4
Yes I know about project, but sometimems it produces a lot of points.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
Show messages: All  1-2  3-5
