Isocurves on several faces.
6862.1
Hallo Michael, is it possible to make isocurves to work on several faces simultaneously and follow one cuvrve?
For example I select faces than run script and and select place where to put isocurves.
Check the pic:
My Portfolio: www.samardac.com
A lot of my Tutorials!
6862.2 In reply to 6862.1
I would love to see such a tool, like a loop cut tool :)
Kuto.ch / freelance graphic designer and 3D generalist
6862.3 In reply to 6862.1
Hi Andrei,
It's difficult because there is no guarantee on any arbitrary joined set of surfaces that isocurves from each adjacent surface will make a closed loop like that. The U/V directions of each surface at joined edges are not necessarily aligned to one another.
What you show there looks like a planar section cut which you can do currently by drawing a line and using Construct > Curve > Project. Select the line, run Construct > Curve > Project, and then select your solid as the target object and you should get a result like that.
6862.4 In reply to 6862.1
Here's a kind of simple example, see the attached 3DM file. Generate an isocurve along the plane like this:
If you now generate an isocurve on the sphere at that same ending location, you'll get a result like this:
The plane isocurve follows the UV structure of the plane, the sphere isocurve follows the UV structure of the sphere, each of those surfaces has a fairly different control point grid structure to it, and so their isocurves do not follow a total straight path when done segment-by-segment like that.
If you want something that follows a straight cut path across surfaces, that's going to be a planar intersection curve which is a different type of generation process than an isocurve. You can get a planar intersection result by projecting a line onto the object though.
6862.5 In reply to 6862.4
Yes I know about project, but sometimems it produces a lot of points.
