Blend shapes problem
All  1-2  3-4
6857.3 In reply to 6857.1
Mark,
The other issue is that the shapes are quite close together and the upper shape is offset (not centered on) from the lower shape, as viewed from above. For edges this different, that makes a smooth transition very difficult; as you can see.
Ron
6857.4
Thank you guys, you helped me a lot.
The hint with bringing the shapes closer together and centering them out a bit is good. Although I haven't changed the shapes a nice blend without intersections could be made.
Show messages: All  1-2  3-4
