Blend shapes problem
6857.1
I want to blend two round objects (see attachment) with G2 and a curvature of at least 1.
Although planar sections and add points improved the initial blend a lot I don't get rid of those intersections completely.
Is there a better way to do this?
Size: 126.9 KB, Downloaded: 62 times, Dimensions: 1785x1209px
6857.2 In reply to 6857.1
Hi Mark, it will be difficult to blend that because your hole is tracing out a fairly different shape than the surface shape.
If you make the hole to be closer in shape to the surface that will help to make a planar sections blend work better, see the attached file for an example.
6857.3 In reply to 6857.1
Mark,
The other issue is that the shapes are quite close together and the upper shape is offset (not centered on) from the lower shape, as viewed from above. For edges this different, that makes a smooth transition very difficult; as you can see.
Ron
6857.4
Thank you guys, you helped me a lot.
The hint with bringing the shapes closer together and centering them out a bit is good. Although I haven't changed the shapes a nice blend without intersections could be made.
