You are right on the planes. I went back in and fixed them in moi3d also closed up the polylines. I usually close all the lines in TurboCad as It has the provision of selecting duplicate lines. I wish moi3d did. I then exported via pdf file, checked it and opened it in Vcarve. That came in clean and cut really nice.
The only problem I have exporting pdf is I can only import to Vcarve. That puts my CoralCad and TurboCad out of use. so I have to re-orient to 0,0 using Vcarve. That's ok as there i can clean up duplicate lines
I think the big culprit was as you said " not planar " Is there a way to align without re-drawing? I'm presently on F8 with 3 to go.
I'm doing this fast so I might not be clear. I'm thinking faster than I tyoe.
Here's a couple attachments to help clear it up.
You sure have been a big help. I'm new so I need it.
Thanks again.
Marv
