How to set the 3 axis in a 2D View ?
All  1  2-4
6852.2 In reply to 6852.1
Hi olaf,
> e.g. if I draw a circle in top view window how can define the z value?
There are a few different ways - if you're going to do a bunch of circles at the same z value use View > CPlane to set the construction plane to your z value height and then they will all go on that level when you just directly draw them in the Top view. Right click on View > CPlane when you're done to reset it.
If you want to put just one individual circle at a particular z value, you would probably draw in in the Top view at the z=0 level initially, then go to an elevation view and move it upwards. You can move things by using the Transform > Move command or there's also a shortcut way by just dragging on the object. To move by a specific distance type in the distance value before you start dragging the object. That will trigger "distance constraint" which will constrain the movement and let you get the particular elevation you want.
In the future I want to add in some more point input methods that would make it easier to specify a numeric z value while letting you pick the x and y values with the mouse, right now there isn't really anything set up for doing that all in one single point pick.
A very speedy easy method ;)
Select Command Circle
Click somewhere without mouse release = Helper Lines
Now move the mouse always without release it on the Z axe and look the distance D on the bottom screen
Release the mouse when you have the wished Z and draw your circle! ;)
Alas we can't type the wished distance during the Helper Lines use for max decimal precision! ;)
EDITED: 8 Aug 2014 by PILOU
6852.4
Thank you for the fast reply
Show messages: All  1  2-4
