Creating a gap or grove in a shallow angled corner
All  1-6  7-9
6851.7 In reply to 6851.6
Hi Paul,
> For some reason if I used Inset, then tried selecting the corner lines to Fillet, it wouldn't work.
Do you still have this particular model handy? If you'd like to get more information on why Fillet didn't work in that case, if you could post the model file I can take a look at it and see if I can offer any hints.
6851.8 In reply to 6851.6
can you post some example surfaces/walls where inset doesn't work?
This is what needs to be seen....
6851.9
Hi Paul
This works
Create the inside surface , separate then select all faces and extrude , from them you can fillet or chamfer the outer edges
I hope this is on the right track
cheers
shayne
Show messages: All  1-6  7-9
