Creating a gap or grove in a shallow angled corner
All  1-3  4-9
6851.4
Hi Paul
I would look at a few methods
sweep a circle or profile down the edge and remove for a groove
or boolean diff down an edge and chamfer either edge to make a V which with a 2 measurement you can get a very narrow V that goes almost right through
or chamfer for a flat
cheers
shayne
6851.5 In reply to 6851.4
Maybe another possibility is to start with a surface that has not been thickened, and then break that apart and use Extrude with the tapered option something like this:
6851.6
Shayno's looks kind-of like what I'm up against. Except not only do I have a bunch of low-angle vertical panels coming together, but each panel also has low-angle horizontal angles too.
The only solution I could come up with was to extract a line from the corner, extrude it without caps, then shell the result and use that as a boolean. It's not quite what I wanted, but it's probably good enough.
Unrelated to this problem, but related to the project I'm working on, I realized that adding in a way to have smooth/rounded corners on the Inset tool like we've got in the Offset tool. I've been needing to make panels and wanted to have rounded corners on them. For some reason if I used Inset, then tried selecting the corner lines to Fillet, it wouldn't work.
-Paul
6851.7 In reply to 6851.6
Hi Paul,
Do you still have this particular model handy? If you'd like to get more information on why Fillet didn't work in that case, if you could post the model file I can take a look at it and see if I can offer any hints.
6851.8 In reply to 6851.6
can you post some example surfaces/walls where inset doesn't work?
This is what needs to be seen....
6851.9
Hi Paul
This works
Create the inside surface , separate then select all faces and extrude , from them you can fillet or chamfer the outer edges
I hope this is on the right track
cheers
shayne
Show messages: All  1-3  4-9
