Curve Approximation, Extension?
6849.1
Hello,
Is it possible in MoI to perform curve approximation and extension? For instance being able to select a curve and then be able to extend that original curve along a G1 or G2 path? It might be useful if surfaces created from those curves needed to be trimmed away to avoid any sort of surface anomalies. I realize trimmed surfaces can be sort of limiting in some cases but if trimming can be done as a near final step before joining it may alleviate the need to fight some surfaces.
6849.2 In reply to 6849.1
Hi OSTexo, it is possible to do a G1 extension by using the Edit > Extend command. That extends a curve to a second boundary object. You first select a curve that you want to extend, clicking near the end you want to extend, then select the boundary object:
In the future I want to beef up this command some more and give it some more options but currently it's very basic.
For curve approximation there is the Rebuild command:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
6849.3
Hello Michael,
Thanks for the info. I have attached a little movie that will probably explain a bit more. I'm not quite sure how VSR is doing it, but as you can see it is actually moving the control points and keeping the number of them intact.
EDITED: 8 Aug 2024 by OSTEXO
6849.4 In reply to 6849.3
Hi OSTexo, yeah currently there isn't anything in MoI to do that particular style of curve extension, but I think it should be possible to add in the future when I get a chance to do various improvements to the extend command.
That type of extension where it's not like a separate segment stuck to the end of the curve can tend to swoop and curl off kind of unexpectedly in many situations though.
