Script for selecting the startpoint of a curve
6848.1
I want to visualize the start point of a selected curve.
The following script doesn't work:
script:
moi.geometryDatabase.showPoints();
var curves = moi.geometryDatabase.getSelectedObjects().getCurves();
var startpoint = curves.item(0).getStartPt();
//startpoint.selected = true;
startpoint.setProperty( 'selected', true );
Another question:
Is there a way in MoI to reverse the direction of a curve i.e flipping start and end point?
6848.2 In reply to 6848.1
<< Is there a way in MoI to reverse the direction of a curve i.e flipping start and end point?
Just press Tab then write Flip ;)
6848.3 In reply to 6848.2
Merci beaucoup monsieur! :-)
6848.4 In reply to 6848.1
Hi Martin, the getStartPt() method on curves returns a "data structure point" which is a lightweight object that contains only x,y,z coordinates in it. It isn't the type of point object that goes into the geometry database and has those other various properties like style, hidden, selection, etc...
What you probably want to get at are the "edit points" of the curve (the ones that show with Edit > Show pts), but unfortunately currently the edit points of a curve or surface are not individually addressable by script, so there isn't any way to script that particular thing currently.
6848.5 In reply to 6848.4
Hi Michael, thanks for the explanation.
