How to build it into solid mesh
All  1-9  10-11
6845.10
Thought I'll give it a go :) hows this? broke the curves into 3 groups and used network...
6845.11
Hello,
Blend works quite well on this shape with just a couple of problem areas where the surfaces pinch. If possible you could run your curves past your finished model, Extrude or Sweep those construction surfaces, perform your Blends and then perform a final trimming operation on your surfaces before Joining them and capping the object into a solid.
Show messages: All  1-9  10-11
