Script for Isocurves to automate it.
All  1-6  7-19
Works cool!
But U+V must be made in 2 pass ! (we have the Menu U+V , U, V visible)
Does this normal ?
EDITED: 30 Jul 2014 by PILOU
6841.8 In reply to 6841.7
> Does this normal ?
It depends on the surface you're using it on - but yes often the edge that you select as the generator will be running in the U or V direction and in that case only the opposite one will work with that edge. You would then need to select an edge in the other direction to make the other set.
6841.9 In reply to 6841.8
Ok Not a big deal ! ;)
so French version will be enable in few time! :)
Done!
http://moiscript.weebly.com/multiiso.html
6841.10
I just keep - Both. But, yes I think direction menu have no need.
My Portfolio: www.samardac.com
A lot of my Tutorials!
6841.11
Some tutor on how to use MultiIso and DistortCurves scripts to make tree:
tree
EDITED: 30 Jul 2014 by ANDREI SAMARDAC
6841.12 In reply to 6841.11
Cool use of the distord curves!
6841.13
Wow, love these scripts! MultiIso, DistortCurves and Randomize offer a lot of power to get rid of order and smoothness, when desired.
6841.14
This is a "turbo" version of Michael's MultiIso script :)
EDITED: 7 Mar 2022 by SMIRNOV
6841.15 In reply to 6841.14
Seems don't work on a box! ??
Only menu appears : Select Source Edges then nothing!
Works fine on a deformed sphere 3D!
EDITED: 26 Jan 2015 by PILOU
Original MultiIso does not do box either, unles Separated.
TurboIso has only U direction?
6841.18
is there a difference between MultiIso+/MultiIso Scripts and the _cMorph Script? Because I did get errors if I run MultiIso+, but no problems with the _cMorph script. And I see they are similar, or they aren't?
6841.19 In reply to 6841.18
They are totally different!
Cmorh draw only from one curve to another one curve ! Surfaces are not taken in compt!
Of course at the end you can make a Loft if you want! :)
CMorph don't work with angles curves!!!
Lineweb can also help you in certain cases! (angles curves)
MultiIso + draw curves on surfaces (volumes)! ;)
EDITED: 13 Mar 2021 by PILOU
Show messages: All  1-6  7-19
