Script for Isocurves to automate it.
All  1-9  10-19
6841.10
I just keep - Both. But, yes I think direction menu have no need.
My Portfolio: www.samardac.com
A lot of my Tutorials!
6841.11
Some tutor on how to use MultiIso and DistortCurves scripts to make tree:
tree
EDITED: 30 Jul 2014 by ANDREI SAMARDAC
6841.12 In reply to 6841.11
Cool use of the distord curves!
6841.13
Wow, love these scripts! MultiIso, DistortCurves and Randomize offer a lot of power to get rid of order and smoothness, when desired.
6841.14
This is a "turbo" version of Michael's MultiIso script :)
EDITED: 7 Mar 2022 by SMIRNOV
6841.15 In reply to 6841.14
Seems don't work on a box! ??
Only menu appears : Select Source Edges then nothing!
Works fine on a deformed sphere 3D!
EDITED: 26 Jan 2015 by PILOU
Original MultiIso does not do box either, unles Separated.
TurboIso has only U direction?
6841.18
is there a difference between MultiIso+/MultiIso Scripts and the _cMorph Script? Because I did get errors if I run MultiIso+, but no problems with the _cMorph script. And I see they are similar, or they aren't?
6841.19 In reply to 6841.18
They are totally different!
Cmorh draw only from one curve to another one curve ! Surfaces are not taken in compt!
Of course at the end you can make a Loft if you want! :)
CMorph don't work with angles curves!!!
Lineweb can also help you in certain cases! (angles curves)
MultiIso + draw curves on surfaces (volumes)! ;)
EDITED: 13 Mar 2021 by PILOU
Show messages: All  1-9  10-19
