ping - Max Smirnov
 1-2  3-22  23-42  43-62  63-82  83-87
6837.43
>>I updated my post with new error message
Lets wait the next MoI v4 beta
>>However generally I have the following error intermittently when trackpad navigating & resizing within NE interface.
Sorry, I don't use trackpad, so I can't find a solution of this problem right now.
But few weeks ago I made some changes in functions which affects on getCanvasWindow. I will release a new NE version soon.
Metin
>> I feel like a real coder now, having changed a "," into a ";". :D
Thank you :) It was just a typo.
Marco
Thank you
But I have no plans to continue development of the Subd script this year.
6837.44 In reply to 6837.43
Hi Max.
@You : “Lets wait the next MoI v4 beta”
Wise decision!
@You : “But I have no plans to continue development of the Subd script this year.”
No problem Max. I can understand.
You already did a wanderul job (and also for free!)
Ciao.
6837.45 In reply to 6837.43
Hi Max
Thanks for the update v.0.98.
FYI
>> I made some changes in functions which affects on getCanvasWindow.<<
Despite the changes, the error perists with2 finger trackpad gestures.
TypeError: undefined is not a constructor (evaluating 'this.getCanvasWindow()')
moi://ui/nodeeditor/core/main.js line 4508
4504: case "touchend": type="mouseup"; break;
4505: default: return;
4506: }
4507:
4508: >> var window = this.getCanvasWindow();
4509: var document = window.document;
4510:
4511: var simulatedEvent = document.createEvent("MouseEvent");
4512: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
I understand that without a MacBook Pro or trackpad periphery device you can't test & find solution, but am reporting it so you are aware.
EDITED: 25 Nov 2017 by JFH
6837.46 In reply to 6837.45
Hi James,
thank you for this bugreport
I made some changes to main.js
http://moi.maxsm.net/nodeeditor/main.js
Try it
6837.47 In reply to 6837.46
Hi Max
Thank you for main.js
It fixed the error message, however there is still some anomalous behaviour with zoom (2 fingers up & down)
Sometime it works, while other time it draws a selection box. This is also true for panning: works intermittently.
Also control clicking on a node does not create a copy of the node.
This is a particularly useful feature, but I think it may have been absent prior to new main.js
Thanks for looking at this. At least now it is possible now to work with NE in v4
6837.48
Hi Max,
i found a bug in nodeeditor...
if you have a slider or knob you can change values with the mousewheel - but if you use a MagicMouse2 or a trackpad it causes NaN if you scroll sideways...
if i go to interface.js and delete all the:
WidgetKnob.prototype.onMouseWheel = function(e)
var v = this.internal.position;
var delta = e.wheelDeltaY/Math.abs(e.wheelDeltaY)/100;
var time = LiteGraph.getTime();
if ( time - this.local.wheelTime < 50 ) { delta *=5 }
else if ( time - this.local.wheelTime < 100 ) { delta *=2; }
this.local.wheelTime = time;
v += delta;
if (v> 1.0) { v = 1.0 } else if (v < 0.0) { v = 0.0 }
this.internal.position = v;
this.properties.value = this.properties.min + (this.properties.max - this.properties.min) * this.internal.position;
this.properties.value = this.properties.value.toFixed(this.properties.digits);
this.updateThisNodeGraph();
this.graph.setisChangedFlag(this.id);
No more Mousewheel ;-(
but no more NaNs :-)
THX for nodeeditor!!
Ralf:)
looking for moments of inspiration...
6837.49 In reply to 6837.48
Hi Ralf,
thank you for bugreport.
Try to replace this line
with this one
var delta = e.wheelDeltaY || e.wheelDeltaX; delta = delta/Math.abs(delta)/100;
6837.50 In reply to 6837.49
YES! Thats it!
The mousewheel doesnt make any NaNs anymore :)
Thank you
Ralf:)
6837.51 In reply to 6837.50
I fixed Knob and Slider nodes.
You can download updated interface.js here: http://moi.maxsm.net/nodeeditor/
6837.52 In reply to 6837.51
Tireless repairing! ;)
PS new French lang.js (3 dec 2017)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
edit: same address but modified!
Does all that (+ nodeditor) works also for the V3 or it's only for the beta V 4 ?
EDITED: 2 Dec 2017 by PILOU
6837.53 In reply to 6837.51
Hi Max,
Thanks for node editor update.
where we put interface.js and index.htm file ?
6837.54
Frenchy Pilou
Yes. The current version of nodeeditor are fully compatible with all v3/v4 win/mac MoI versions.
Finema
nodeeditor/nodes/interface.js
nodeeditor/index.htm
6837.55 In reply to 6837.53
Hi Finema,
just there:
Ralf:)
6837.56 In reply to 6837.55
Thanks Max & Ralf :)
Hi Max,
In either MoI3, or MoI4beta, if the MoI window is not maximized,
and the External scripts screen is too big, or bigger in size,
(Mine has about 395 files in it.),
Then the external scripts screen only shows when the left (or right) mouse button is held down.
6837.58 In reply to 6837.54
Hi Max,
I would like to get your thoughts on the idea of making a small alteration to Widget/Knob.
Often in developing node circuitry, There is the need for dialling even integers only ( or at other times, only odd numbers). This could easily be achieved by changing the "Digits" field to an "Increment" field, as shown:
The default setting of course would be 1, and Decimals could also be accommodated, for example, using 0.01 instead of 2 as presently used to represent the same. I also think it is more intuitive.
I understand that making this change couldl create backwards compatibility issues, but perhaps this could be avoided by having RMB options of Digit (Default) and Increment (2nd option).
Thanks for your continued development
I am excited to get my hands on v1
P.S. Also sometime ago we discussed the inclusion of button & switch, that you had planned to repurpose code that you have already developed for a different application.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.689
Another revision that would be simple (I think) but very useful would be to use createRadialGradient() method to lay a radial gradient (dark grey to light grey) behind grid in NE interface. This would offer visual cue to locate area within main window in reference to the totality. At the moment, at time when you fully zoom out, if nodes are not shown, there is no way to be sure which way to pan to move towards the centre to find node circuitry. Of course a "zoom to extents" function would be better but also more involved (I imagine)
EDITED: 7 Dec 2017 by JFH
6837.59
Sorry, I was extremely busy last week.
Brian
I can't reproduce it. Anyway I use MoI's built-in functions to show the window, so I can't fix this issue by myself.
I need to significantly change all widget nodes to implement this feature. Sorry, I can't make it in the nearest future.
I rewrote this node for using with NE.
You can download an updated interface.js from my site: http://moi.maxsm.net/nodeeditor/
I'll add this feature in the next NE release.
6837.60 In reply to 6837.59
Max
Thanks for switch node, it is masterfully resolved & will be very useful.
>> need to significantly change all widget nodes to implement this feature. <<
Is this also true if feature is a RMB second state option of knob only?
Thanks again for your continued development of NE
6837.61
Hi Max,
is it possible to have a feedback node similar to Hoopsnake as discussed in the nodebundle thread.
Ref this video https://www.youtube.com/watch?v=QefqhzIz_ak
Barry
6837.62 In reply to 6837.59
Wow thats a nice switch/button..
Thanks a lot Max!
Ralf:)
Show messages:  1-2  3-22  23-42  43-62  63-82  83-87
