ping - Max Smirnov
 1-5  6-25  26-45  46-65  66-85  86-87
Hi Max.
Maybe you could find interesting this conversation started at http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.17
We are talking about your subDiv tools :)
Ciao!
6837.27 In reply to 6837.24
Hi Brian
>>In MoI3, the first time it is run, it defaults to UV mode, not U mode. Repeat runs open in U mode.
I tested this script with 3.0(win) and 3.1(mac), and I can't reproduce this UV/U bug. :(
6837.28 In reply to 6837.25
Hi Marco
>>ERROR : Cloth.v.0.96.2014.02.23.zip (Mon Nov 3 23:56:24 2014)
Thank you, I know about this script error. I'll check it this weekend.
>>Maybe you could find interesting this conversation..
OK, I'll read it right now
6837.29 In reply to 6837.27
Hi Max,
Upon further testing: If there is a space following the final U, then the UV mode pops up, the first time only.
(I was picking up a trailing space when highlighting for Ctrl_C, Ctrl_V) (silly error)
6837.30 In reply to 6837.29
I added a command which removes all spaces from script parameters.
You can download new version of the script from my file archive.
http://moi.maxsm.net/files
6837.31
Hi Max,
I just nticed that cMorph doesn't work in the MoI beta. I get this error message:
SyntaxError: Expected an identifier but found 'var' instead
cMorph.js line 47
43: curvesF.setInput( 0, objectpicker.objects );
44: curvesF.setInput( 1, 'Refit' );
45: curvesF.setInput( 2, 0.001 );
46: var curves = curvesF.calculate(),
47: >> var closedCurves = curves.item(0).isClosed && curves.item(1).isClosed;
48:
49: moi.ui.beginUIUpdate();
50: moi.ui.hideUI( 'SelectionPrompt' );
51: moi.ui.showUI( 'MorphOptions' );
Many thanks in advance for updating it.
Regards,
— Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
6837.32 In reply to 6837.31
there is a , instead a ; at the end of the line
Perhaps it helps if you change it...
Ralf
6837.33 In reply to 6837.32
Yep, that turned out to be the culprit, thanks!
Here's the corrected version:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8682.79
Regards,
— Metin
6837.34 In reply to 6837.33
Hi Metin,
thank you! :)
I uploaded fixed version to my file archive
6837.35 In reply to 6837.34
@You : "I uploaded fixed version to my file archive"
Perfect Max! Thanks.
6837.36 In reply to 6837.19
Hi Max
I updated my post with new error message
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757
6837.37 In reply to 6837.17
Hi Max
Excepting the bug "Invalid function argument 1 line0" I get when running pentakisDodeca&TruncIcosa.nod (see http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.757), all other .nod files run perfectly.
However generally I have the following error intermittently when trackpad navigating & resizing within NE interface. It appears to be triggered by 2 finger gestures (pan & zoom)
TypeError: undefined is not a constructor (evaluating 'this.getCanvasWindow()')
moi://ui/nodeeditor/core/main.js line 4509
4505: case "touchend": type="mouseup"; break;
4506: default: return;
4507: }
4508:
4509: >> var window = this.getCanvasWindow();
4510: var document = window.document;
4511:
4512: var simulatedEvent = document.createEvent("MouseEvent");
4513: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
Thank you for your great work
6837.38 In reply to 6837.37
Hi Max
I spoke too soon. Attached is an example that runs v3 but not v4.
EDITED: 14 May 2019 by JFH
6837.39 In reply to 6837.34
Hi Max,
I feel like a real coder now, having changed a "," into a ";". :D
Thank you too!
Regards,
— Metin
6837.40 In reply to 6837.39
Yes you just understand that the world's stability depends only on "'" , ",", ":" and sometime ";" without speak about "{" or "}" :)
And alas surely miss some important ones! For exaple the "." :D
6837.41 In reply to 6837.40
@ Frenchy: :D
Regards,
— Metin
6837.42 In reply to 6837.28
Hello Max.
I've assembled another (I hope) useful model to test your SubDiv scripts and its results.
You can find it at :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8667.47
Ciao ;)
Marco (mkdm)
6837.43
Lets wait the next MoI v4 beta
Sorry, I don't use trackpad, so I can't find a solution of this problem right now.
But few weeks ago I made some changes in functions which affects on getCanvasWindow. I will release a new NE version soon.
Metin
Thank you :) It was just a typo.
Marco
Thank you
But I have no plans to continue development of the Subd script this year.
6837.44 In reply to 6837.43
Hi Max.
@You : “Lets wait the next MoI v4 beta”
Wise decision!
@You : “But I have no plans to continue development of the Subd script this year.”
No problem Max. I can understand.
You already did a wanderul job (and also for free!)
Ciao.
6837.45 In reply to 6837.43
Hi Max
Thanks for the update v.0.98.
FYI
>> I made some changes in functions which affects on getCanvasWindow.<<
Despite the changes, the error perists with2 finger trackpad gestures.
moi://ui/nodeeditor/core/main.js line 4508
4504: case "touchend": type="mouseup"; break;
4505: default: return;
4506: }
4507:
4508: >> var window = this.getCanvasWindow();
4509: var document = window.document;
4510:
4511: var simulatedEvent = document.createEvent("MouseEvent");
4512: simulatedEvent.initMouseEvent(type, true, true, window, 1, first.screenX, first.screenY, first.clientX, first.clientY, false, false, false, false, 0/*left*/, null);
I understand that without a MacBook Pro or trackpad periphery device you can't test & find solution, but am reporting it so you are aware.
EDITED: 25 Nov 2017 by JFH
Show messages:  1-5  6-25  26-45  46-65  66-85  86-87
