angles math help
All  1-2  3-14
And make rotate 60 then 15 of a cutting plane is not sufficient without move the cylinder?
6835.4 In reply to 6835.2
Ahh, the ole intersection line from 2 angled planes trick!!!
That sounds like it may be the answer. any other comments to confirm welcomed....
Thanks Dan....
6835.5 In reply to 6835.4
Hi Burr yeah I agree with Dan's method - since you're interested in the projected angle in each view it's easier to get the axis line you want by the intersection of 2 extrusions rather than doing rotations.
It's definitely true that if you rotate a line in the top view, it will change the angle of the line as viewed in the the front view.
6835.6 In reply to 6835.3
I don't think it is - the second rotation changes the "as viewed" (projected) angle of the plane's surface normal direction.
Basically the Top and Front views are both connected to one another because they share the same right-left x-axis direction. So if you do any transformation in the top view that changes position in the x axis (including rotation), it will disturb the angle as viewed in the other view.
When you want things to adhere to a particular 2D silhouette it's usually better to work more with the silhouettes and have those extruded...
6835.7 In reply to 6835.5
Thanks again. 2 planes intersection it is.....
6835.8 In reply to 6835.2
>>> DAN : "... (still waiting on v3 to buy) ..."
Definitely OT, but you may buy v2 now, get immediate access to the v3 beta and the free update to v3 once it comes out.
6835.9 In reply to 6835.8
Yup that's correct, if you purchase v2 now you will get a free upgrade to v3 when the final version comes out which won't be too much longer.
6835.10 In reply to 6835.9
Thanks for the heads-up. I might do that.
6835.11 In reply to 6835.9
Sorry about the OT post, but I had a couple questions about V3 and licenses.
1. If I buy a V2 student license now, can I still upgrade to V3 for free when it comes out?
2. What's the difference between the student version and regular version? Are there any license restrictions? (e.g. can I still use it when I graduate, and what about upgrading to a new release from an older student version?)
3. Will there be a student version for v3?
6835.12 In reply to 6835.11
Hi Dan ..
I can answer the first couple as Michael has pretty much answered these in the past ... If you buy V2 now you can upgrade to V3 when it comes out. The student and the pro versions are identical.
I am sure he will issue a V3 student version.
cheers,
eric
6835.13 In reply to 6835.11
Hi Dan, yes just to make sure it's all clear:
Yes, any v2 purchase right now for any version including the student version will get a free upgrade to v3 when v3 comes out which won't be much longer.
The software is exactly the same between the student version and the regular version. The only difference of any kind is in the license agreement, but the difference there is about the student version license not being transferrable to someone else, not about how you use it. You can use the student version after you graduate, and you can also use the student version for commercial work either before or after you graduate.
You can upgrade to a new regular non-student version from a student version license, when getting an upgrade license any previous version license will be sufficient for the upgrade.
Yes.
6835.14 In reply to 6835.13
Thanks, Eric and Michael. That's what I suspected but I wanted to be sure before buying.
EDITED: 28 Jul 2014 by MONTAGMAN
Show messages: All  1-2  3-14
