fillet question
hhal (HHAL9000)
21 Jul 2014 (1 of 3)
6832.1
Is it possible to fillet edges after a Boolean operation such as those highlighted ? I can't get the fillet to work on these edges.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
blowlamp
21 Jul 2014 (2 of 3)
6832.2
You may just need to use a very small radius as a fillet can sometimes consume surprisingly large areas of a part where faces meet at less than 90 degrees to each other, as per your picture close to the two outer holes.
Martin.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
hhal (HHAL9000)
21 Jul 2014 (3 of 3)
6832.3
In reply to
6832.2
Thanks Martin.Yes reducing the fillet right down did the trick.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
