Mirroe Update
All  1-5  6-8
683.6 In reply to 683.5
Hi Jesse, I'm glad the mirror history technique will be useful to you.
I guess I probably should enable history for mirror by default.
In a future version I want to add more types of symmetry functionality that would allow for doing edits on a circle like you show there currently with scale1d, but instead just by dragging one side of it. It may be a bit difficult to set that up so it may be a while though.
683.7 In reply to 683.2
M.G. said
"History updates are not enabled by default for all the Transform commands. I'm a little bit worried about automatically turning on history all over the place, since it can sometimes lead to unexpected results if you wanted to edit the newly created objects as independent objects. Maybe mirror should be an exception though."
That's why you should think of adding a choise when copying, mirroring etc.
This choise should be INSTANCE or NEW
Instance: History update is on, no matter which command you choose
New : A copy or a mirroring of the initial object, a completely new object.
A instance->new transformation would be very nice to have too.
Just some ideas for V2.0
***There is always a better way to do things... Just find your Moment of Inspiration***
683.8 In reply to 683.7
Hi JTB, yes definitely a good idea for 2.0. It will be a bit of work to get general support in for instances first of course...
Show messages: All  1-5  6-8
