fuselage - wing joints using blend?
 1-4  5-22
6827.5 In reply to 6827.3
> Seems your curves are not on the surface!
Yeah it seems to be a bit off. But it's close enough that it can be used to trim the surface ok. Once you have done the trim then discard the curve and use the new trim edge instead for doing the blend.
Does the Network function gives not a better result ? (orange)
6827.7 In reply to 6827.6
Probably not, because most likely you'll see under close examination that the network result does not connect in a totally smooth shape to the upper and lower surfaces. That smoothness to existing surfaces is why Blend is often desired for this type of thing.
But what is "better" does depend on what the particular goals are.
6827.8 In reply to 6827.2
Hello Michael,
Thank you for your feedback and the feature! This helps a lot.
S.
6827.9
Instead of starting a new discussion I thought I'd add to this one (because I have a similar problem).
I'm trying to get a nice fillet between the wing and fuselage and I'm not happy with the results. Can't say I
understand the finer points of planar sections.
Some advice would be welcome ...
Size: 673.2 KB, Downloaded: 34 times, Dimensions: 1920x1080px
6827.10
Hello,
You can get a much better starting result by drawing a tangent line off of the leading edge of the wing and moving the fuselage forward. You'll still probably need to carve up the blend into a few sections over the course of the connection, but the wing position seems to be causing the blend to fold over onto itself a bit. I've also found it helpful to keep a few copies of the original surfaces complete to use as construction surfaces especially when blending. If you have a more simple version of the model without holes it would be helpful to post that.
6827.11
Okay, here'ya go....
6827.12 In reply to 6827.9
Hi jetblast, right now one of the problems you're having is trying to put the blend into a fairly constrained small amount of area.
Blend wants to adapt itself to the surfaces on each side of the blend. When there is not much space available it will cause the blend to buckle as it tries to violently and suddenly switch its shape in a small amount of space.
You'll probably want to make the hole to be fairly larger in size on the main body.
6827.13
Hi all,
Just for the heck of it I tried the fillet tool and .... it worked !!!
In reality when I make this plane I'll just put some light weight spackle in the joint and smooth it with my finger. I'm sure it won't look as good as the MoI fillet.
I just thought this would be good practice for learning the planar section command.
Thanks guys.
Size: 479.4 KB, Downloaded: 30 times, Dimensions: 1920x1080px
6827.14 In reply to 6827.13
Hi jetblast, I'm glad you got a good result with fillet!
A Planar sections blend should be a good candidate with this too, if it's given more space to work with. I've been trying it over here and it seems to be getting confused right at the trailing edge area though, it might have something to do with the angle of the wing making it think it needs to flip the blend in that spot. I'm going to try and investigate it some more.
6827.15
Hello,
I'm getting a sort of unusual split in the middle of the blend where it looks like the curve direction changes and folds over on itself. Interestingly this also seems to happen when I just try to blend a section of the junction.
6827.16 In reply to 6827.15
Hi OSTexo,
Sounds similar to what I'm getting also - is this with "Planar sections" being used?
Can you please post the 3DM file of your current blend so I can test with it over here also?
Thanks, - Michael
6827.17
Hello,
Here is the file. Yes, I am using the planar sections option. I originally thought that that unusual blend was happening because the connection point of the wing was pushed too far to the rear of the fuselage, and when that was pushed forward a bit that cleared itself up, but I started getting that unusual blend happening. The situation became a bit better when I limited the blend distance, but it began showing up again on other blended areas, and it really doesn't solve the issue at the trailing edge of the wing since that is a difficult surface to patch in. It does seem visually to flip right in the midpoint of the blend. Hope the file helps to see what is happening.
6827.18 In reply to 6827.17
Hi OSTexo, I think that weird shape is a bug that I can do something about, it seems to be triggered when the "chord line" connecting the two sides is fairly slanted compared to the edge tangent at that point. It tries to use the chord line as an indicator direction for which side to orient towards but it looks like that's not so good to use when it gets slanted basically.
I think I can do something about that part, but there is a larger problem remaining for this type of sharp trailing edge thing which is that the blend is trying to do 2 different things at the sharp discontinuity area, and it doesn't really help that the shapes are on the same plane there, they're trying to be smooth to 2 different shapes right there. I think that the blend mechanism would need a pretty substantially different strategy in order to handle those sharp areas.
So I'm going to see what I can do about the sudden internal shift thing, that's probably fixable. But it will probably work better for a planar sections blend to avoid the sharp discontinuity on the trailing end and instead have a small tightly bent corner (which in other kinds of cases tends to be bad, but in this situation it's probably needed though, since "Planar sections" behaves quite differently than things that come away perpendicular).
Some kind of corner patch construction like you have on the other side may be a better strategy for a sharp trailing edge... Maybe if the blend would sort of have an "extended rail" type of shape more like how filleting happens that might work for that kind of thing.
6827.19 In reply to 6827.18
The "extended rail" type thing would be something like this - the blend would be synchronized to each side like you've got here:
But instead of it actually stopping there, the blend would continue on with the shorter surface being implicitly extended so it would form an extended blend piece like this:
Then the extended pieces are intersected and the blend would be trimmed to form the trailing edge of the blend, like this:
I guess that seems more likely to work than trying to directly make a single surface cross section in the sharp corner...
That seems pretty tricky to attempt in an automated way, and I'll need to look at various other discontinuity cases to see how generally feasible it is... Could be something to try in v4. Probably until then a tight bend in the wing surface trailing edge rather than an actual discontinuity would probably work with Planar sections.
6827.20
Hello Michael,
I can see that extended rail Blend being very useful for a few different surfacing problems, especially if you're able to keep G1/G2 continuity between the surface and the blend itself. I'm really enjoying being able to stay in MoI more and more even for some of these surfacing operations, great job.
6827.21 In reply to 6827.20
Here I've attached a test run of the extension technique, this one was done by actually making the wing out of an extended self-intersecting curve to start with in order to do the blends. The blend here was done in 2 separate pieces, with just regular blend not planar sections. Then it was a bit tricky to trim them, they did not intersect cleanly because of their shallow overlapping area so I had to generate an intersection curve, tweak a couple of points on it and then trim both surfaces to that common curve. Then I deleted the self-intersecting extended wing, trimmed the extensions off the self intersecting curves and then lofted those to get the final wing.
Final result is on the left, extended pieces working pieces on the right.
Seems to be a really good result, what do you think?
During some of the recent Blend overhauls I did experiment some with other ways to deal with discontinuities, without success... One attempt was to make an average of the 2 different cross section shapes at the corner and then gradually morph that back to the regular blend shapes as it travels some distance away from the corner. The problem with that is the loss of continuity in those areas.
6827.22
Hello,
The result does look very good, it looks like you've kept G2 on the wing/fuselage connection. I think I tried something similar before and trimming that trailing edge junction but I either got that weird surface flipping or problems with the trimming because the two surfaces were skimming each other. The blend issues were part of the reason I asked the question about continuity options in other tools. Having that capability puts MoI into an entirely different area of solution. I'm not complaining, but I think it would be great to have such tools within MoI, if nothing more than for MoIs legendary implementation of the features.
Show messages:  1-4  5-22
