Hi jetblast, like Pilou says using Ctrl+C and Ctrl+V is one good way. You don't actually have to use 2 separate sessions of MoI, you can open the file with the stuff you want to import, select the specific things and do Ctrl+C, those objects are now copied to the system clipboard. Now open up your target file and do Ctrl+V and you'll have the objects moved over.
Another way is to select the objects you want to move and do a File > Export, which writes only the selected objects to the file you pick. Then you can do a File > Import later on to bring that reduced file over.
> As it stands now (I think) when I import something from one file I get everything in that file with no opportunity to
> pick what I want. I just get everything.
> Is there a way to pick and choose what I want ?
There isn't any way to do it selectively at import time, but you can do it instead at export time, using File > Export writes just the selected objects instead of everything.
But probably copy/paste is the easiest.
