Little annoyance with Helix
6813.1
Hi there,
Super small thing
When you use the Helix tool and you get to the last step, the "cancel" button is in focus
So when I press the spacebar to switch view it actually press the "cancel" button
That's just a minor annoyance :)
-- Kuto.ch / freelance graphic designer and 3D generalist / Switzerland
6813.2 In reply to 6813.1
Hi Shapenoid, I can't seem to repeat that over here - over here when I push Space at the final stage of Helix I don't get anything happening at all. I tried both Mac and Windows versions...
Can you post what you have for your Space shortcut key so I can try it with that?
Are you doing any other particular steps like typing in values in certain inputs or something like that?
Do you actually see the cancel button get a dashed outline on it ? (if it's really focused it should look like that)
6813.3 In reply to 6813.2
Can't seem to be able to reproduce it, it's working correctly in new documents
The button was dashed yes.
Maybe it's because I had used the tab key to enter values before...
You can close the thread :)
