Variable Fillet Radius Problem - V3 June
All  1-5  6-8
6805.6
Doh, I keep forgetting about the need to work in the 1 to 1000 range for the model size. Michael is that still the case in V3 ?
Thanks for reminding about it.
~Kevin~
6805.7 In reply to 6805.6
Hi Kevin,
There's been progress in V3 to make various things more adaptive to object sizes rather than using only a fixed fitting tolerance, but it's still possible to run into problem areas.
Your particular case here was just a bug - I've fixed it up for the V3 final version so your original case at your original small size will work ok.
6805.8
Ok, thanks Michael
Being able to work at any size is a big plus.
~Kevin~
Show messages: All  1-5  6-8
