active control points after the draw curve tools
6802.1
When I draw a curve, a line or a polyline, every time, after this operation I adjust the curve with the control points.
It will possible that the freeform curve tool ends (and in general for all the drawcurve tools) with the visible control points?
Filippo
_________________________
That's a brilliant day to design!
6802.2 In reply to 6802.1
Hi Filippo,
It's possible to do this by editing the curve drawing script command to add a line of script that turns on control points.
To do this go to the \commands sub-folder inside of MoI's main installation folder and edit the file DoCurve.js inside of a text editor.
At the end of the file, find this:
	else
		curvefactory.commit();
And change it to this by inserting the one new line before the .commit() :
	else
		curvefactory.getCreatedObjects().setProperty( 'showpoints', true );
Then when you draw a freeform curve it will have control points turned on for it when the command finishes.
I would not really recommend doing this to every single command though, for other commands it's possible to set up a shortcut key that will turn on control points for whatever was the last created object. To do that set up the following script on a shortcut key and press that key when you want to turn on a just created curve's control points (you do not need to select the curve first):
script: /* turn on points for last created object */ var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.showPoints = true; }
6802.3 In reply to 6802.2
The first one is what I need.
The second script is usefull for all the other shapes: circle, ellipse...
Thank Michael
Grazie
Filippo
