OSX 64bit?
6800.1
is it possible to create a MOI3D V3 OSX with 64bit?
i convert big IGS to OBJ files and often the conversion fails because of out of memory errors.
Best regards
Chico
6800.2 In reply to 6800.1
Hi Chicco - Mesh the model in parts, not all at once - Then with your polygon application, import the obj's one at a time, then export from there as a whole model again - you will now be able to render there or you can import the whole model into your standalone render app.
Martin Spencer-Ford
6800.3 In reply to 6800.1
Hi Chico,
Sorry no, there's a lot of work yet to be done before a 64-bit version of MoI will be possible. It is something that I want to work on for the future but will not be for v3.
Please see here for some tips on how to avoid running out of memory:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5322.2
