V3 beta Jun-27-2014 available now
 1-5  6-25  26-45  46-59
Wohaaa! The famous PushPull of Sketchup inside Moi ! Excellent!
PS I send you the French translation of the UI! ;)
EDITED: 28 Jun 2014 by PILOU
6790.7
Michael G. this is again fantastic! Just downloaded, and will have to dig into it deeper later.
Thanks again!
Michael T.
6790.8
Wow!! Fantastic! I'm very impressed with this new extrude tool.
P.S. Many thanks for the filesystem functions. I'll update CustomUI scripts right now.
List of news of the last beta in French :)
http://moiscript.weebly.com/liste-des-mises-agrave-jour.html
6790.10
Nice job on the Extrusion & Boolean modifications!
A few days ago I noticed that the AI Export options Projection View dropdown choices don't change with the view port settings.
Would it be possible to have the list populated with the current settings?
The export works correctly eg. right exports left, top exports bottom etc. so not a showstopper just a bit confusing.
6790.11 In reply to 6790.5
Hi Danny, thanks for the detailed testing of the new face extrude!
> The file attached looks like the image below, when you extrude the face that is style
> 'Red' in the Z+ direction and end up with the result like in the second image the body
> becomes a joined surface.
This is because it forms a "non manifold" edge, basically after that cut there is now a spot on the model where 4 different faces are coming together at a single edge, it's sort of like the model has a pinched area in it where opposite sides of the model are touching each other. That more or less makes it into a self-intersecting shape and there will be problems with analyzing the volume of things like that.
In your case here it's this particular spot here, notice how opposite sides of the model are coming into that same one edge, that's a type of self overlapping:
That's more or less a case of just "don't do that"... There needs to be a little bit of clearance space in spots like that rather than having opposite sides of the shape come to a single touching edge.
Even though there aren't any naked edges in that model, it doesn't read as a "solid" object type because there is an error classifying the solid volume regions of it. Something will only read as a solid if it both has no naked edges and also has been able to form at least 2 region volumes for the outside region and inside region. EDIT: actually after double checking, this particular case doesn't read as solid not because of regions but because of that one particular non-manifold edge which ends up belonging to 4 faces. A manifold edge must belong to only either one same face for a closed surface or otherwise be joined between just 2 surfaces, all edges must be manifold for an object to read as solid).
If you widen this spot here over just slightly then it should avoid the grazing pieces and then your same red face extrusion should generate a solid ok after that, see the attached 3DM file.
EDITED: 29 Jun 2014 by MICHAEL GIBSON
6790.12 In reply to 6790.10
@ danperk,
That probably should be easy to tune up, I'll take a look tommorrow.
6790.13
Thanks Michael! Looking forward to V3 release! :)
6790.14 In reply to 6790.11
> This is because it forms a "non manifold" edge........
Yeah like I said I wouldn't go to this extreme however thanks for the explanation I did search for naked edges and was puzzled that nothing showed up, now I know what to look for if I come across this situation.
6790.15 In reply to 6790.14
Hi Danny, MoI does try to get rid of non-manifold edges after doing booleans, but the main way that it does that is by breaking things apart into separate solid regions so different volumes that have common edges between them become separate objects. But that does not handle this type of situation you had here.
The non-manifold edges will probably become naked edges after you save such a thing out to a file and read it back in again, much of the stuff for going into various file formats including 3DM expects the model to be manifold.
6790.16 In reply to 6790.15
The Extrude auto booleans looks so sweet, thanks for the new beta !
Just wondering, can't this push/pull be the normal behavior when you sub-select and drag a face ? so you don't actually need to use the extrude command ?
I'm asking that because I have half read the beta log. I just lauch MoI, create a cube, and my first thought was that I could just select and drag a face. Seems very natural too me, I had to come back on the forum to undrestand I have to use the extrude command.
EDITED: 29 Jun 2014 by PAQ
6790.17 In reply to 6790.16
Also Michael, it will be great to not only extrude but also shell, for examaple to change size of holes, or increa/decreas chamfer.
Also it will be great to move holes.
Push-pull extrude boolean is a great addition. Nice way to stay in the creative zone rather than dealing with the mechanics of boolean operations.
Ed
6790.19 In reply to 6790.16
@ PaQ,
I do want to do face dragging in the future but I'm waiting until I have a "move face" mechanism. Dragging is meant to be a quick way to do a Transform > Move, and moving a face is a somewhat different operation than extruding it, except for the special cases where the surrounding pieces are all at 90 degrees to each other.
In a CAD program usually to move a face means to extend the surrounding surfaces until they reintersect the newly positioned face, for example:
Extrude gives a much different kind of result, like this:
They're different operations but they happen to give the same results for certain kinds of objects like boxes.
6790.20 In reply to 6790.17
Hi Andrei,
That is something I'd like to explore in the future. But it may be difficult to put in shell because shell already does something else when given a face sub-object selection, it uses those selected face as the openings for the shelled result.
It might fit in to offset maybe something like a "build side walls" option for when offsetting a face, that would be for doing pockets or protrusions using an offset type construction rather than an extrusion type.
These kinds of things will probably work better with "face transforms", similar to what I described above in the reply to PaQ, that's where after doing some edit on a particular face like moving, rotating, or scaling it, the surrounding faces are extended and reintersected with the updated face. It's something that I want to work on in the future.
6790.21
Thank you Michael for your incredible work, this new beta is a huge release!
I'm really thankful of this whole community and software, MoI is becoming my main tool and it feels so good to use.
I'm quitting my day work to work as a freelancer from 1st september and I can't wait to show you guys some of my latest stuff :)
shapenoid.com
6790.22 In reply to 6790.1
Michael,
great work! Just a question, how it works Nsided? I haven't understand it... Thanks. Davide
6790.23 In reply to 6790.22
Hi Davide,
There's some discussion on Nsided here http://moi3d.com/forum/index.php?webtag=MOI&msg=5721.2
6790.24 In reply to 6790.23
Thanks Danny!
6790.25
It makea sense of course, thanks for your time !
Show messages:  1-5  6-25  26-45  46-59
