Using Shift and Ctrl to switch to panning and zooming
All
1
2-6
Michael Gibson
26 Jun 2014 (2 of 6)
6789.2
In reply to
6789.1
Hi Metin,
> Is this also possible in MoI, switching to panning when using Shift + MMB, and zooming using Ctrl + MMB?
Sorry no there's no way to do that particular combination currently with the middle mouse button.
When you have the middle button set to rotate you can use right drag (with no modifier keys) to pan.
But there are also methods with the Alt key using the regular left drag (just pen tip pushing).
Alt + left drag = pan (when having middle button swapped to rotate like you've currently set, otherwise it's rotate).
Alt + shift + left drag = rotate (or pan if swap pan/zoom is not set).
Alt + ctrl + left drag up/down = zoom
You might try the Alt key way and see if that works for you.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin Seven (SEVENSHEAVEN)
27 Jun 2014 (3 of 6)
6789.3
In reply to
6789.2
Thanks for the info, Michael! I'll play around with the options.
Have a nice weekend,
Metin
metinseven.com — daily updated blog | sevensheaven.nl — 3D design
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
27 Jun 2014 (4 of 6)
6789.4
Ah, Alt + RMB is an alternative option to zoom. That way I can avoid using the pen tip for navigation.
I've changed my Blender viewport navigation settings accordingly. After all, MoI is more important than Blender of course. ㋡
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
27 Jun 2014 (5 of 6)
6789.5
In reply to
6789.4
Hi Metin, also you may have already seen but Shift + Right drag will do Pan or Rotate, whatever the opposite of the plain right drag will do.
So if you like you can use the Right button with modifier keys to do everything.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
28 Jun 2014 (6 of 6)
6789.6
In reply to
6789.5
Yep, and I've noticed that Ctrl + RMB also zooms, next to Alt + RMB, so I'm a satisfied man again. ㋡
All the best,
Metin
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1
2-6
