Rhino to Moi
All  1  2-5
6778.2 In reply to 6778.1
Hi Poebel, right MoI does not handle block instances so you need to run the Explode command in Rhino first before saving out the 3DM file, so that your block instances are converted to regular objects.
After that though their layer assignments in Rhino should come through as style assignments in MoI. If you still have a problem with the styles not working after that, can you please send an example file to me at moi@moi3d.com so I can take a look at it and see what's going on?
6778.3 In reply to 6778.2
Although we're going to see instances in the first v4 betas? <3
6778.4 In reply to 6778.3
Hi Max - I don't have any specific schedule planned out for v4 yet...
6778.5
thank you for the fast answer.
The solution you mentioned works correctly but Rhino gets very slow and for many layers, blockĀ“s and objects its not the best way.
I think i will do it like i said in my post, save all layers as an .3dm and merge them afterwards.
There is a well working skript on "McNeel Wiki" which batches the .3dm layer export. It's called "Export Layer Objects".
Thank you anyways!
Thomas
Show messages: All  1  2-5
