fast image from screen shot
All  1-3  4-11
6774.4 In reply to 6774.2
And ... the code for turning off/on the edges?
Is there it? In order to insert it in the script.
Filippo
_________________________
That's a brilliant day to design!
6774.5 In reply to 6774.4
Hi Filippo,
For that the script needs to go through objects and on each object get its edges and set the edges to be hidden or not.
That should go like this for hiding them:
var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { breps.item(i).getEdges().setProperty( 'hidden', true ); }
And for showing them the same thing, just passing false at the end instead like this:
for ( var i = 0; i < breps.length; ++i ) { breps.item(i).getEdges().setProperty( 'hidden', false ); }
You can just insert those whole chunks of code before and after the screencapture just like the other ones.
EDITED: 19 Jun 2014 by MICHAEL GIBSON
6774.6 In reply to 6774.5
Bene
I've done another step:
for turn on the high lights
moi.view.specularHighlights = true;
for turn off the high lights
moi.view.specularHighlights = false;
at work
script result
... humm... a script to take a coffee?
Thank you
Filippo
6774.7
Hi Fillipo
The customui has a handy screen shot button left mouse click for grid right mouse click for no grid
using the lighting style chrome you easily get snapshots like this
Thats not easy to get the twist ends to match up
cheers
shayne
Or use the PDF export! ;)
6774.9
>Shayne
Hi Shayne
Where I can find it?
> Pilou
Hi Pilou
I save little images in jpg, and I use them in a database
Filippo
6774.10 In reply to 6774.9
6774.11 In reply to 6774.10
Merci Pilou!
Show messages: All  1-3  4-11
