Trouble while creating my own keyboard shortcusts
6765.1
Hi there,
due to the nature of my project, I have to use MOI more and more, and therefore I wanted to create some keystrokes of my own. While doing so, I ran into trouble and my shortcuts do not want to work. For example:
I wanted to make the Hide object work with the h key. So i made a new shortcut, told it, that I want the key h and the command Hide and what i get is errors. Not always the same, but mostly Reference Errors, cant find variable. Itried it with "hide" and "Hide object", always the same result. What am I missing here?
Heiner
6765.2 In reply to 6765.1
Hi Heiner!
Hide is a macro.
quote:
There are a few buttons in the UI that run script macros instead of commands: Hide, Reset all, Select all, Deselect all, and Invert. This is so they can be used while a command is still running, so these functions are slightly different than a regular command. To hook these up to a shortcut key fill in the Command part with one of the following scripts:
Hide:
script:moi.geometryDatabase.hide();
Lock:
script:moi.geometryDatabase.lock();
Reset all views:
script:moi.view.resetAll();
Select all:
script:moi.geometryDatabase.selectAll();
Deselect all:
script:moi.geometryDatabase.deselectAll();
Invert selection:
script:moi.geometryDatabase.invertSelection();
6765.3
Cool,
now its working ...
Thanks.
One more question: What if i want to have shortcuts with CTRL or SHIFT?
Heiner
6765.4 In reply to 6765.3
Hi Heiner,
just write "Ctrl+" or/and "Shift+" and the key...f.i.
6765.5 In reply to 6765.1
Hi Heiner, yeah for some particular functions they're not actually what is called a "command", they are instead some script code. Some various things that can be activated while you are actually still running inside of a command are like that.
There's some more information in the help file topic for keyboard shortcuts here:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
