Hi Bob, do any of the above comments and examples help get you pointed in the right direction?
> I am modeling the leg as a separate item.
As I described above, I would not recommend doing it that particular way if you want to have the leg blended to the table body by using filleting. It would probably be better to model it as a larger all connected object initially (see my example 3DM file above), fillet that, and then once you have the filleting done how you want it, cut the leg off from the main object using a boolean operation as a last step.
If you try to build the leg as a separate piece right from the beginning it will be difficult for it to get filleted, because you will end up with a lot of little fragmented pieces which are not good for filleting.
