Spiral Bevel Gear and Pinion
All  1-5  6-11
6763.6 In reply to 6763.5
Rotating the pinion and/or the pinion cutout(s) in Right view, by -90 degrees, seems to mesh with the gear.
As drawn it seems slightly smaller than it should be... (It should be re-done using the below pinion crown/heal point.)
In Right view, the left heal corner point of the gear face is located at ( 0, -0.5 * Gear OD, - Pitch Apex to Crown on Gear ).
Get the face by rotating a certain line by (90 degrees - Gear Face Angle).
Add two lines nearly perpendicular to the face line, about 87 degrees and 89 degrees, just so the cutouts extend past the gear blank by a tiny amount.
In Right view, for the rotated pinion, the upper heal corner point of the face is at ( 0, Pitch Apex to Crown on Pinion, 0.5 * Pinion OD ).
Get the face by rotating a certain line by (90 degrees - Pinion Face Angle).
EDITED: 13 Jun 2014 by BEMFARMER
6763.7 In reply to 6763.6
The gear is very easy in MoI also, using the prior heal point, and 3 trimmed lines. Just do revolve, two planars, Boolean union the parts of the gear
blank to make it a solid. Then do a Boolean difference with the 37 circular arrayed cutouts from the iges gear cutout file.
Did a Crown Gear with 87 tooth gear, and 17 tooth pinion, from the crown gear demo excel file.
The pinion is easy. It is just a spur gear. Pinion tooth cutout circular array is done in Top view
The gear steps can be easy, but it did take some time. For the half tooth cutout, mirror, loft, and join, and array circular, is done in the Front view
The .3dm file for the gear is 42,129 kb. (very large)
The .3dm file for the pinion is 647 kb.
The Boolean difference for the gear teeth was done in groups of 9 to 13.
The final gear had to be rotated 180/87 degrees (2.0689+degrees), to mesh with the pinion.
Ctrl-C copy from MoI, and Ctrl-V paste into Geomagic Design (Alibre) was successful.
6763.9 In reply to 6763.8
Great work Brian,
cheers,
eric
6763.10 In reply to 6763.8
Brian, I'm not trying to be funny but the image looks like a straight bevel gear, rather than a spiral bevel gear. Am I mistaken?
Mike.
6763.11 In reply to 6763.10
Hi Mike
Thank you for your observation.
I think that you are correct.
According to Wikipedia, "a crown gear is a type of bevel gear where the pitch cone angle is 90 degrees."
Thanks to you, I now see that some columns of both of the excel spreadsheet are hidden, for example H39.
To unhide bevel gear excel columns, highlight columns C and L, right click, and select unhide.
There are a bunch more formulas.
The tooth shape of the gear seems a little strange to me.
I'll have to do some more investigation, comparing the crown demo with the bevel demo.
I'll have to try changing the bevel excel sheet to "flat," a pitch cone angle of 90 degrees.
Brian
Show messages: All  1-5  6-11
