New tutorial!
All  1-6  7-16
6755.7 In reply to 6755.1
Thank you for posting the video. Clear and informative. Looking forward to the next one.
Mike.
6755.8 In reply to 6755.6
I am thinking about Flow function, but seems there are in the result some different levels between letter of a same word! :(
EDITED: 5 Jun 2014 by PILOU
6755.9
@Mike
thanks! Will keep you guys updated
@Pilou
Yes I'm aware of that, that's the reason why I don't use it :)
shapenoid.com
6755.10 In reply to 6755.8
That's because you're using the "Rigid" option in Flow - the way the Rigid option works is it only flows one single point at the center of the object's bounding box, and uses that to move and rotate the entire object.
Since each of the curves you show there in a line of text has a slightly different bounding box, they will all end up using slightly different positions on the base curve as their base point.
6755.11 In reply to 6755.10
yes but if I don't choice rigid Letters are pespective deformed that I don't want! ;)
6755.12 In reply to 6755.11
My guess is that the warping will be less evident if arc and base line are equal length?
Dries
6755.13 In reply to 6755.12
No that will be the same result! Persperctive deformed! ;)
6755.14 In reply to 6755.1
Cool tutorial Samuel, thank you. I didn't know that it matters from which side objects get selected.
Will watch it again and also use your shortcut list to speed up my workflow.
-Martin
6755.15 In reply to 6755.11
Right, so Flow just does not do the particular job that you want there, you would need to use some other method for rotating your text, such as Transform > Rotate, or Transform > Orient...
In the future when there is such a thing as a "Group" in MoI, it would then probably work to make Flow with the Rigid option take the center of an entire group rather than just each individual object and that would solve your particular issue here.
6755.16 In reply to 6755.15
A little Workaround ;)
Draw a solid Plane around the letters
Select Plane + letters
Make Flow (Line / Arc Circle )
Select Plane result
Erase it!
Et voilĂ !
Letters are not deformed! ;)
Show messages: All  1-6  7-16
