New tutorial!
All  1-13  14-16
6755.14 In reply to 6755.1
Cool tutorial Samuel, thank you. I didn't know that it matters from which side objects get selected.
Will watch it again and also use your shortcut list to speed up my workflow.
-Martin
6755.15 In reply to 6755.11
> yes but if I don't choice rigid Letters are pespective deformed that I don't want! ;)
Right, so Flow just does not do the particular job that you want there, you would need to use some other method for rotating your text, such as Transform > Rotate, or Transform > Orient...
In the future when there is such a thing as a "Group" in MoI, it would then probably work to make Flow with the Rigid option take the center of an entire group rather than just each individual object and that would solve your particular issue here.
6755.16 In reply to 6755.15
A little Workaround ;)
Draw a solid Plane around the letters
Select Plane + letters
Make Flow (Line / Arc Circle )
Select Plane result
Erase it!
Et voilĂ !
Letters are not deformed! ;)
Show messages: All  1-13  14-16
