Mystery with swept profile
6751.1
I'm trying to design a screw thread more suited to 3D printing than standard threads.
As a trial run I drew a 8mm standard thread profile, swept it around a helix and unioned it with a core - no problem
Then I drew a modified screw profile and repeated that procedure but couldn't get the core and swept solid to union. I've checked everything I can think of, and started from the beginning several times but am getting nowhere.
Along the way I noticed that I couldn't Boolean difference the swept profile (the object 'coil') with a straight line to section it so it looks like I've stuffed the helix or sweep step.
The attached file contains the screw profile (which is a closed curve), the helix (spiral), the swept solid (coil) and the core.
I think that I'm doing something wrong at the helix step...
Any pointers greatly appreciated.
6751.2 In reply to 6751.1
Hi Mike,
The problem is you have overlapping surfaces, when you swept your profile Boolean union is getting confused because it's trying to union the spiral body to it self as well as the cylinder.
When you look down the centre of the spiral body the lines indicated there are underlying surfaces within the body.
Hiding the front face reveals the overlapping surfaces inside.
I've attached a cleaned up version where I removed the inner spiral overlapping surfaces, extruded another cylinder surface, trimmed it up and joined it to make a solid, it should union to the cylinder now.
6751.3 In reply to 6751.2
Thank you, Danny.
Any ideas on how to avoid this problem in the first place?
6751.4 In reply to 6751.3
Hi Mike,
You'd probably want to have a smaller piece for just the thread, so that the part that's spiraling around doesn't run into itself. Surfaces that cross back over themselves (even just barely grazing) will tend to cause a lot of problems with intersection calculations.
So for example you'd want the inside part to be just a straight extruded cylinder surface and not a spirally type thing in that spot.
Some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=767.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=490.36
http://moi3d.com/forum/index.php?webtag=MOI&msg=4623.1
6751.5 In reply to 6751.4
Thank you, Michael.
I trimmed 0.1mm from the top of my screw thread profile (as shown below) and had no further problem.
